Xenon adjustment for france
Adam C Jul 18, 2007
  1. Adam C
    Adam C Mine a manual
    29
    Hi,
    Mine=2001 Allroad with Xenons.
    Can sombebody tell me whether I have to have the pattern adjusted for contiental europe? halford/main dealers seam really vague.
    thanks
    Adam
  2. matt_o121
    matt_o121 2.8Q
    84
    i am not sure about xenon's but the normal headlights have a lever next to the rear of the dip beam unit which you have to just move to the side to change the beam cut off for continental use.
    it is outlined in the owners handbook,it should be the same for xenon units
  3. Adam C
    29
    Well you'd think so... the manual says that adjustment should be made by main dealer due to high voltages, but the dealer says adjustment isn't necessary. They're so bright I don't want to upset oncomming lorry drivers late at night on the way down.
    thanks
    Adam
  4. dan_b
    dan_b Member
    263
    @Adam, did you ever get an answer on this? I have the same query for my A4 Xenons, wonder what I do if I hop over the channel...
  5. rallye
    rallye New Member
    20
    Hi the xenons have a lever the same as normal lights I did the lights on my s6 before a trip to switzerland last year. One lever is easy to get at the other one is a bit harder it took me 10 minutes in total with lights turned off so no high voltages.
  6. BahnStormer77
    BahnStormer77 BahnStormer
    2,754
    53
    Any idea on wether this lever exists on the 2011 A6 C6 (last of the C6's)?
  7. crispin
    crispin Member
    167
    on the C6 its a dealer job and it will cost lots!! I have just come back from trip to Austria and I did not bother. That is my advice as it really makes no difference. If you really want to you can buy stickers at the tunnel which stick on the front even for Xenons.
