Wrapping Front S3 Splitter - Any Advice?
Silky-S3 Jan 30, 2012
  1. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    341
    So, I'm thinking of wrapping the centre part of my front bumper, the grey part in the pic below:
    to match the front grill, and fog surrounds. Has any one done this (pics would be good)? How difficult was it? I was going to get it painted but don't fancy that as I may want to go back to standard at some point.
    Does the middle part come off separate from the bumper, or is it a bumper off job? Also how hard is it to use the wrap, looks like it might be tricky? Just looked on eBay and platy of wrap on there, which is the best type to go for?
    Thanks for any help guys :)
    SparkyMcA likes this.
  2. s3ollie
    s3ollie Member
    762
    The splitter is part of the bumper and cant be seperated. (atleast on my 2007 bumper)
    Was thinking of doing mine gloss black (paint) or carbon wraping.
  3. Juicy Jen
    Juicy Jen Jen @ Juicy Detailing Site Sponsor
    828
    121
    We had it done in carbon fibre wrap on the rs3....took the guy ages tbh
    I'll see if I can get a picture for you
  4. Silky-S3
    1,407
    341
    Thanks!
  5. Juicy Jen
    828
    121
    I was going to get it done on my S3 when it comes back from the dealer as I think it looks much better
  6. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    Whilst mine is int the body shop getting repaired they are gonna spray my splitter and fog grills gloss black to match the grill.
    Thinking about doing the rear at some point too.
  7. rickyquicky
    rickyquicky Member
    342
    A friend of mine has a window tinting/car wrapping workshop, i've seen him wrap cars, parts etc.
    Wrapping just that part would be very tricky...the problem with wrap is getting it around tight curves and corners without creases/tearing it/getting it to stretch and stick, is hard.
    You could give it a go, the only tip I could give is to use a heat gun (or worst case a hairdryer lol) and a LOT of patience, and you would almost definately have to wrap the 3 'bars' (those plastic bits that go down between what you want to wrap and the bumper) seperately, or just leave them. And also apply it a bit at a time starting from one side working to the other, getting rid of any air bubbles along the way.
    In actual fact, JUST PAINT IT!!! Trust me will be much easier. Hope that helps :thumbsup:
  8. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    have you thought about that plastic coat paint stuff?
    Spray it on and when you're done and want to go back to standard, you just pull it off.
    Like wrap.
  9. Silky-S3
    1,407
    341
    The problem with paint is stone chips, and since that bit does not come off the bumper, masking it up....
    Carbon Fibre Vinyl : 3M UK & Ireland - reading some good stuff about this. Anyone used it?
  10. ScottD3
    15,161
    1,121
    I've used 3M gloss black on my door trims and its lovely stuff. Very easy to work with and once you get some heat on to it its so much more mouldible than the matt I used.
    If don't don't want to paint and not very confident or much experience in wrapping, I would look in to the plastic coat stuff. It's only one solid colour but it looks to be really easy to apply to and take off.
  11. Cruiser89
    1,484
    221
    Does come off bud.
    Bodyshop have taken mine off my old bumper and placed on the new one as it wasn't damaged. they are spraying whilst it's off. I understand your concerns about stone chips but it's only the same as if your bumper were to get hit.
  12. rickyquicky
    rickyquicky Member
    342
    That part painted will be no more likely than the rest of the bumper to get a stonechip...
    Wrapping just that bottom bit will be a headache, and your going to need to cut in the edges of the vinyl if that bottom part doesn't come off. I'd rather be masking edges than cutting them!
  13. audigex
    audigex Active Member
    591
    45
    Two minute photoshop job, in case it helps at all :)
  14. poli84
    poli84 Member
    425
    57
    Looks great!!!
    Make it happen Silky!
  15. rodaz
    rodaz New Member
    13
    Hi
    No problem - i wrapped it in silver, just loose the screws from the bottom and pull it out
  16. Silky-S3
    1,407
    341
    Cheers mate, thats good to know. I'll look into this plastic coat stuff...
  17. Silky-S3
    1,407
    341
    That sounds promising can you explain how it comes off? Do you need to take the full bumper off to get at it?
  18. Silky-S3
    1,407
    341
    Cheers!!! Looks awesome. Humm, black or carbon...
  19. JamesS4cab
    JamesS4cab Well-Known Member
    1,189
    94
    This what your looking for?
  20. Silky-S3
    1,407
    341
    Epic, thats a top job mate. Cant believe you did that with out removing it from the bumper!
    JamesS4cab likes this.
  21. JamesS4cab
    1,189
    94
    Its all about the skill of the desk monkey!!
  22. essIII
    essIII Active Member
    285
    35
    I've done my front splitter and rear diffuser with black plastidip - it sprays on like paint but forms a rubbery coating. Best of all, if you cock it up or change your mind, it peels off.
    Plastic Coatings, Rubber Paintould post some pics up but she's a filthy S3 at the moment!
  23. Silky-S3
    1,407
    341
    Looks intresting mate, your pics would be good! Did you spray the front splitter while it was still on the bumper?
    Have you tried peeling it off yet, does it come off easy?
    Thanks!
  24. essIII
    285
    35
    Yep, I had to peel it off the chrome grill surround once, and off my garage floor! And my jeans. Comes off remarkably well.
    Sprayed the grill when off the car (was an accident damaged one, so needed some plastic weld too) and then the splitter and diffuser were sprayed while on the car, masked with lots of newspaper!
    Pics attached - poor lighting in the underground car park at work!
  25. damo.h
    damo.h DVLA Say it's Black
    3,610
    67
    If your wrapping the front insert you'll have to wrap each fin seperate then cut it into the corners then wrap the main area with a couple of mm overlap.
    Plasticote is good stuff but better on internal apps. A good amout ofClearcote over the top should see of the stone chips but for how long who knows. As that area is low to the gravel.
    You going gloss or matte ?? If not carbon. If going carbon you wanna be using 3m 1080 viny, if gloss / matte go for 3m ij380 cv3 for maximum durability
  26. essIII
    285
    35
    Just FYI - Plasticote and Plastidip are two very different products.
  27. JamesS4cab
    1,189
    94
    Have you got a link to Plastidip pls?
  28. essIII
    285
    35
  29. Silky-S3
    1,407
    341
    Thanks all, lot to think about. I think I'm going towards carbon wrap but the plastic spay looks really good, along with much better ease of use I suspect!
    Can anyone 100% confirm or not if the front splitter can be removed from the bumper, without removing the whole bumper? If so, anyone got a guide? Is it just a few clips/bolts underneath?
    Thanks again :)
  30. damo.h
    3,610
    67
    Cheers for that, was going of what Scott posted and read it as plasticote lol
    What's the longevity of that stuff like ?
  31. ScottD3
    15,161
    1,121
    I got my bloody plastic wording all messed up. I mean plasti dip.
    sorry all.
  32. ScottD3
    15,161
    1,121
  33. Silky-S3
    1,407
    341
    Just seen this mate. So its just a few screws and then pulls out?
    Thanks!
  34. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,227
    319
    get it done mate looks so much better , i like it in gloss black
  35. Virdee
    Virdee Active Member
    172
    25
    For starters the front splitter can definitely be separated on a MY12 car.
    I had mine done in gloss black. Looks really nice against Suzuka and finishes the front end off IMO.
    Removal is very simple - two Torx screws either side and then just clips off.
    I bought a new part from Audi and had it painted.
  36. Silky-S3
    1,407
    341
    Nice one, this project is now a GO!
    You got any pics of yours?
  37. Cruiser89
    1,484
    221
    As mentioned, mine was removed.
    Few torx 10 screws and the rest is just clips that hold it in place :)
  38. rodaz
    rodaz New Member
    13
    So it is :)
  39. Silky-S3
    1,407
    341
    Does anyone know if the rear defuser also comes off relatively easy? May as well do both at the same time.
  40. DJ-S3
    DJ-S3 Active Member
    690
    43
    Just been talking to my panel beater friend about doing this. Looks awesome!!! Think i'm going to try Gloss black though. Shame that plastic coating rubber stuff doesn't come in Gloss black, would of been perfect!!
