wrapping chrome grill surround!
S3featesV9 Jul 28, 2011
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Vinyl wrap just arrived, finally after 2 weeks off poor custom.
    Just wondering what's the easiest way to get it off the car? ive heard of people removing the bumper to do it, is this really necessary?
    thanks
  2. Rob_k
    Rob_k Member
    93
    I removed mine by using a trim removal tool and prying it off in situ
  3. dannyh
    dannyh Nogaro S3
    792
    12
    I used good old brute force with mine and out it came, diddnt do too much damage just bant a couple of clips, but they easilly bend back
  4. S3featesV9
    1,032
    12
    so i remove the whole grill? or is it just the chrome part you removed?
  5. dannyh
    dannyh Nogaro S3
    792
    12
    if you pull the chrome it will snap! dont do it!!!!!!
    remove the black plastic grille, the chrome is attached to that
  6. ptr
    ptr Member
    128
    yep, i made the mistake of just pulling on the grill whilst applying pressure to the clips with a screwdriver, worked fine apart from one stubborn clip which snapped and now the grill surround sticks out slightly on one side :(
    bumper off just to be safe, if you've done it before it's easy.
  7. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Take the bumper off: 2-3 screws in both arches, couple of on the top when you open the bonnet, pop the 2 sides out and then the bumper just slides off...
  8. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
  9. Westy
    Westy Well-Known Member
    17,443
    1,104
    I've had the chrome part of 3 or 4 times with a screw driver without damaging anything. You lot must be going mental on yours!
  10. voorhees
    16,218
    2,033
    You must have soft sensitive hands Westy lol
  11. Westy
    17,443
    1,104
    I moisturise mate ;)
  12. Jgould
    Jgould MY ARS3!!!
    74
    A small flat blade screwdriver start at the bottom of the middle of the grill and gently prize off working you're way out equally from centre until u have got all the way round takes less than 40 seconds
