wow is this whats causing my problems?
Rogue-24-84 Jan 11, 2012
  1. Rogue-24-84
    Rogue-24-84 Member
    268
    my s3's been missing badly coming and going (more detailed describtion in my other post S3 misfirng) and what ive replaced already..
    well today ive pulled the wiring harness out to inspect it, as ive changed near on every sensor and still nothings coming up on vagcom, anyway i pulled back the plactic sheilding and removed the black tape to reveal this..!!! is this whats causing my problems? because its arking out etc?? can it be repaired or am i looking at a new harness?
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Very typical, you should be ok stripping it all back and reseal with fresh tape, it has been the cause of some misfiring issues in the past.
  3. Rogue-24-84
    Rogue-24-84 Member
    268
    mate its completely shot..!!! i peeled it back some more and the thick brown wire is all brittle and the casing is begining to fall off... from the coil end to pretty much right to the bottom, about 2-3 foot!! and theres a red wire and a blue thats split in places aswell!!
  4. Prawn
    11,413
    3,302
    fairly sure a new coil pack loom is only about £25-30 from the dealers mate, and they're available for this very reason I think!
    Get a new loom section, easiest way
  5. Rogue-24-84
    Rogue-24-84 Member
    268
    contacted awesome gti and the guy there mark said they dont offer one for the 210 or 225 engine, only 150 or 180.... dogged!!
  6. Rogue-24-84
    Rogue-24-84 Member
    268
    this is the extent of the loom.....
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Funked i think...!!!! :(
  7. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,256
    355
    and the dealers said?
  8. Rogue-24-84
    Rogue-24-84 Member
    268
    going to call audi newbury tomorrow and see if its something they can get me, other than that its a case of having to get one out of a breaking s3...... id much rather put a new set of wires in tho tbh as the ones out of a breaking car could be just as knackered as mine when i strip them back!!
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    How the hell did that happen to the wiring!? Looks like someone's had a butchers at it before! Solder up what you can and insulate them again and you should be fine.
  10. aragorn
    18,034
    723
    you can use the "180" version, you just might have some soldering to do.
  11. superkarl
    superkarl MAN OF STEEL
    9,405
    2,379
    bloody hell never seen that before. i mean its heard of and quite common. but never actually seen the extent of how bad it can be.
    at least you've found your prob. and can enjoy a MUCH better running car afterwards
  12. Rogue-24-84
    Rogue-24-84 Member
    268
    i bloody hope so...!!!!!
  13. Andrew@A.L.D
    3,873
    609
  14. Rogue-24-84
    Rogue-24-84 Member
    268
  15. Sandip
    2,440
    91
    Do you know about this hose bud, soz if you're already aware lol
  16. sportstractor
    sportstractor Chugger
    2,709
    im also going to be a complete cretin, but isnt the dv the wrong way around? and no vac line going to it?
    that loom is shocking, iv notice mine is breaking up on the coil pack wiring but not experiancing any problems so going to leave it until it does play up.
  17. sportstractor
    2,709
    also is that a split-r DV?
  18. Rogue-24-84
    Rogue-24-84 Member
    268
    yh had to remove the breather and dv vac to pull it out the way to get the loom out from underneath, yh is a split r aka dogshi te....!! i'll be purchasing a 007 when ive got a few extra quid, thats how they run sideways it should have the little trumpet bit in but i dont like the sound of it so i put the blanking plug in it..
  19. Andrew@A.L.D
    3,873
    609
    Works on mine
    I didn't use the full loom just cut and spliced into the old one so far back
    Done 150 miles on that loom with the 2.0 coil packs and everything is well
    The guy in the workshop is talking s**t
  20. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    They are compatible you've just gotta match each core to the correct one and splice it in (the colours aren't the same) and you do have to butcher the new one for just the bits you need
    I done this a few months back on my 225 bam and I was told that it wasn't compatable by awesome and audi told me I needed a whole new loom for £400 plus :-O
  21. s3dave
    10,110
    736
    £400 + :huh:
    Awesome one is very compatible then.....:)
  22. stumpy83
    stumpy83 one legged wonder
    90
    why dont you just make a new loom maplins with have all the pins that are needed and just use the same plugs if there ok??
  23. Andrew@A.L.D
    3,873
    609
    A days work to do
    I even found the part number for the coil pack loom heat shield and fitted a new one
    8L9-121-659
  24. Metro
    Metro Error
    381
    Hmmm... Well when audi replaced my coil packs the left hand loom came back like that, I taped it up but im still having issues with my boost (which wasn't that bad untill audi had their hands on it!) its booked in now for them to have a look at the problem (gratis + courtesy car) should mention the wiring loom coming back in that state?
  25. Rogue-24-84
    Rogue-24-84 Member
    268
    oi stop hijacking my post you.... haha
  26. Rogue-24-84
    Rogue-24-84 Member
    268
    im gunna try and pull as much of the loom out tomorrow and then replace the broken wires by soldering in new lengths, i'l try and find some coil plugs somewhere and replace them too, i know where there's a 18t bora in a scrappy near me, i'l go see if the plugs are the same...
  27. AARON77
    AARON77 Well-Known Member
    1,322
    26
    Heat shrink
    From any electrical wholesaler
    Then use a heat gun
  28. Rogue-24-84
    Rogue-24-84 Member
    268
    you think that will be ok? thats what my ol man said to do, i thought maybe a new bit of wire should go in? id have to cut it to get the heat shrink on anyway?...
  29. Metro
    Metro Error
    381
    I see how it is xD let me know how you get on, your cars gotta be fixed by next week!
  30. Rogue-24-84
    Rogue-24-84 Member
    268
    yeah.... ive done over 300 quid on it so far but new mafs and lambda's fuel pump etc etc etc, to pull the wires out and find them like this..... i just hope to christ it fixes the problem, because im getting pee'd off keep taking it to bits and not getting anywhere!! and nothing coming up on vagcom.. when you come over if its working i'l take it down the big train station car park and you can have a blast in it ;)
  31. Metro
    Metro Error
    381
    Sounds like a plan xD its just gonna ruin my car for me isn't it! Hopefully mine will be a tad more fun after the map/boost issues are fixed! Would love to know if changing that loom has any effect, ill see if I can get some pics of mine up to compare it with yours, although last time I checked, yours still looks so much worse! Good luck with the fix though! I'll see if audi will fix mine for free since it happened after they played with my coil packs..
  32. Rogue-24-84
    Rogue-24-84 Member
    268
    yeah just keep on at them, say it was running fine when it came in for the work... it sould of came out the same!!
  33. Craig1.8t
    Craig1.8t Member
    108
    9
    A lighter works perfect.
    I'm having problems with my car too, always had a feeling I might be loom, might take my full loom off one day and inspect
  34. Welly
    Welly VX220 SC Driver :)
    10,696
    127
  35. Rogue-24-84
    Rogue-24-84 Member
    268
  36. Rogue-24-84
    Rogue-24-84 Member
    268
    FIXED!!!!!...... :arco:
  37. Welly
    10,696
    127
    Another win on the broken wires front!
  38. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Decent! Well done mate!
  39. Rogue-24-84
    Rogue-24-84 Member
    268
    chopped all the split and broken wires out and soldered in new lengths, its taken me all day but its running like a sowing machine now and drives better than it ever has since ive had it :) well happy
  40. Metro
    Metro Error
    381
    Gratz!
