Would these wheels fit???
Abb May 23, 2011
  1. Abb
    Abb Member
    309
    Hi guys, just wanted to know if some original equipment alloys from a Q7 would fit my 07 plate S4?? The measurements are 9j x 20" H2 ET60.
  2. Sam W
    Sam W Member
    175
    They wouldn't be a straight fit, as the PCD is different, but you might be able to get adapters, you've got at least 30mm to play with in the offset for them.
  3. hades-
    9,482
    646
    you can make them work
  4. Triple.O.G
    Triple.O.G Active Member
    1,113
    They are 5x120 so as above adapters would be needed, maybe wobble bolts but youll need need spacers then as ET60 will prop rub on calipers.
