Would these bolts be too small?
Defratos Oct 5, 2006
  1. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    Hey guys, I've just ordered some spacers: 8mmfront 20mmrear. Now I'm getting the right type bolts, but the lengths aren't exact. Now the standard bolt length is 27mm soooo:
    Front: 27 + 8 = 35mm
    Rear: 27 + 20 = 47mm
    Now I'm getting 35mm bolts for the front (which seems fine) BUT getting 45mm bolts for the rear, Now that's just under 2mm short, would I be fine? or would it be better to be safe rather than sorry?
  2. Ess_Three
    Ess_Three Active Member
    5,383
    15
    You'll be fine with those..
    You have a few mm to play with...about 5mm I seem to remember...so you'll be just fine.
    You have to be careful fitting bolts which are too long as well...especially at the front, as bolts which are too long can pass thtough the disc and hub and hit the ABS sensor ring...bending it as you tighten.
    I found out the hard way! Oops!
