If its face lift, you would probably need to cut the protusions of the body of you car around the wing. Normaly done when you move to the one piece from 2 piece.
Dont no about the wiring side tho, not sure if they're special or anythin.
Yeah rear lights fit no problem, just need to swop a couple of wires over in the plug as light layout is slightly different. I have these fitted to my car as do many other on here.
Rears, yes physicaly, you may need to swap a wire or two over (easy) make sure you get the bulb holders if you can too. What type do you have at the mo? the red/orange or the later red/ white ?
