Would removing the clocks/speedo then refitting same one cause any problem/coding?
ps44u Nov 26, 2011
  1. ps44u
    ps44u Member
    57
    I just wanted to confirm that if I remove the clocks/ speedos from the a3 to change the dials and LCD screen, then refit the same clocks, would I have to recode them ?
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,249
    10,227
    Im pretty sure you will need to recode them.
  3. ps44u
    ps44u Member
    57
    Even if they are the same clocks going back in?
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
  5. ps44u
    ps44u Member
    57
    Hi khufu thanks for your reply, I checked the link and it doesn't work, also if I were to unplug the battery and then remove the clocks would I still get the warning lights?
  6. NHN
    29,389
    1,733
    Usually if its the same clocks plugged back in after initial removal, the angle sensor etc should all clear on a drive, its when you plug in another cluster & then plug yours back in, is when it needs things resetting, but even if it decides to act up as in requiring resetting of things, just requires some simple procedures with vcds, IMMO shouldnt be affected at all with an unplug/plug scenario.
    Buttttt, be very careful with the pcb as to not damage it, as the cluster is the immo system as such, so beware :)
    Sandra likes this.
  7. ps44u
    ps44u Member
    57
    Thanks for your help NHN, i knew you would come through for me!
