Hi all
Today my 1999 APY engine S3 started to misfire under load, seems fine in normal driving but if you put foot down it runs like a bag of nails. Have run VAG-COM and got the following fault codes:-
Address 01: Engine Labels: 06A-906-032-APX.clb
Part No: 8L0 906 018 K
Component: 1.8L R4/5VT 0002
Coding: 05610
Shop #: WSC 06313
VCID: 3763FA8915D63486A4-515A
2 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-10 - Incorrect Flow Detected - Intermittent
17947 - Clutch Pedal Switch (F36)
P1539 - 35-00 - Implausible Signal
Readiness: 0000 0000
My question is will the Clutch Pedal Switch be the cause of the misfire or just an unrelated problem?
Thanks' in advance
Nige
Coding: 05610
Shop #: WSC 06313
2 Faults Found:
Thanks' in advance
Nige
