Would 5x110 offset alloys fit a b6?
allyp Feb 13, 2011
  1. allyp
    allyp Member
    222
    sorry more stupid questions do you reckon 5x110 alloys with et43 would fit the audi thanks
  2. Broken Byzan
    13,244
    468
    not without wobble bolts and appropriate spigot rings.
  3. allyp
    allyp Member
    222
    Ok so its possible then with the bolts and rings then?thanks
  4. quattrojames
    14,068
    585
    5 x 112 wheels with the correct offset really aren't that rare! I'm not sure why you're trying to fit such abnormal wheels!
  5. allyp
    allyp Member
    222
    Lol,just want to see my options before i spend a big wad of money thats al.....l maybe something different as well
  6. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Our A4 b6's have the following 5x112 stud, 57.1 center bore , Offset 43-35. Stick within these guidelines and you should be fine.
  7. Nutkin
    Nutkin Member
    830
    Wobble bolts are your friends , I'm assuming astra wheels?
  8. allyp
    allyp Member
    222
    Well was thinking vectra c ones ,but might still go for the s4 17s presumably they fit straight on
  9. paul20v
    paul20v Audi fanatic
    1,114
    S4 17s will fit straight on
    i would like to see a set of 10mm hubcentric spacers on the rear at least for a bit more stance thou.
  10. allyp
    allyp Member
    222
    Sounds good ,expand on the hubcentric bit as youve lost me lol
  11. matttrs
    matttrs Member
    163
    hubcentric sit on the flange of the hub, making sure they are perfectly centred, they again have a hubcentric lip for your wheels to sit on, so everything sits in the middle of the circle.
    On older spacers for old dubs and other cars, you'd often get wheel wobble from wheels not sitting perfectly central
  12. CMD
    3,015
    17
  13. allyp
    allyp Member
    222
    Ok thanks matt,maybe would look nice with the back wider mmmm
