Would 18x8" wheels.....
Mackers May 21, 2012
  1. Mackers
    Mackers Member
    291
    would 18x8" wheels with a 45mm offset and fitted with 225/40x18 tyres fit my facelift "X"Reg avant, it's dropped 30mm ATM, i have a car show (modified nationals) in 10days and want a set of 18's.
    Many Thanks
    Wayne
  2. CraigG
    CraigG Member
    190
    i suspect it will foul the rear suspension upright at the top (you can barely get your finger in there with standard 17") although depending on the actual tyre profile (varies with brand) you may get away with it, i wouldnt think you would need anything more than a 5mm spacer, if you require one at all.
    Trial fit required.
  3. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    well et35 (i think thats what rs4 alloys are) fit my a5 b5 on a big drop.
    18"x8
    on 225/40's
  4. CraigG
    CraigG Member
    190
    Yep, but that 10mm of space is what is needed, it is very very tight at that top upright. as i say, you might get away with it depending on the profile of the tyre.
  5. Mackers
    Mackers Member
    291
    the wheels an tyres i seen are 225/40x18
    the wheels are 18x8 and ET 42
    they'll be ok yeah?
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    225/40/18 is what you want.
    As for the ET, I'm not sure.
    I'm running ET35 on 18x8.5 with out any issues.
