WOTBOX launch/lift off control
warren_S5 Apr 13, 2010
  1. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Does anyone know if any of the forum members are running one of these on an A/S3?. LINK TO: WOTBOX launch control
    Some details of what it does:
    The WOT Box adds two major features to any car. They are No-lift shifting and 2-step launch control. Both of these features are completely user-programmable using the WOT Box Graphical User Interface.
    The No-Lift Shift feature makes no-lift shifting easy by cutting your engine's ignition for a very short period while you no-lift shift. No-lift shifting is keeping the gas down through the shifft. The ignition cut allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. Keeping your foot down through the shift also allows you to hold boost through the shift, thereby significantly improving your E.T.
    The major benefits are:
    Lower ETs
    Reduced chance of missing a gear
    More consistent, effortless shifts
    Reduced wear on the transmission
    Reduced chance of major transmission damage
    The 2-Step Launch Control modulates the ignition by cutting power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. You can use this feature for a more consistent and more powerful launch in boost!
    Never sure whether these are 'all that' or more gimmick.
    Any thoughts?.....
  2. KRL
    KRL Member
    521
    S3_Dan has got one on his S3. Not sure about anyone else though.
    Not tried one myself so can't say much more. I'd like to know to know if cutting the ignition while WOT has any negative impacts in the long term?....
  3. Jamiekip
    Jamiekip Member
    717
    I had a run out in S3_Dan's car (when it was JonnyC's) just after the WOT box was fitted and it made quite a difference to launches and sprints through the gears.
    It was good, but one I'd consider a nice to have rather than a must have if that makes sense.
    I know Jonny is getting one on the TT too so he must rate it
  4. warren_S5
    7,210
    2,486
    If it could be turned on and off it would definitely be quite useful. Seen some video of an S3 with it on last night, and it was spitting flames with each gearchange :scared2:
    I'll keep an eye on Jonny's threads and see what his thoughts are. This is a daily driver in the main, I'd like something more switchable.
  5. Im sure the wotbox only operates when you operate the clutch when the accelerator is on the floor. During normal driving the car performs as OEM. I did a little reading into it a while ago after watchin a video on youtube with it fitted to an S3 8P. Another mod i have been considering is Water/Meth Injection done a good bit of reading into it and sounds like there are good gains to be had with fitting it. Fitting a WOTBOX IMO is more for someone going to track days and 1/4 miles on a frequent basis.
    Davie
  6. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,451
    589
    Post the video of flames or it didnt happen and you are lying :p
  7. warren_S5
    7,210
    2,486
    Here you go squire...
  8. gynads
    gynads Member
    314
    i want one of these! do you think the S3 in the vid is running a decat? (would it spit flames with a sports cat)?
  9. akash_sky1
    akash_sky1 Active Member
    1,181
    It could be decatted but with a WOT box and cat you could still get flames on WOT shifting with all that unburt fuel going thru the turbo and exhaust...niiiiiiiiiice I like !
    WOT boxes are invaluable for the 1/4 mile and track but not so useful for fast road driving unless you are street racing. They sound uber cool though.
  10. LukeHS3
    LukeHS3 Member
    74
    i would buy one now if i could find somewhere to fit it :(
  11. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,019
    551
    wot box will burn your cat. so decat is a must.
  12. BOSSS3
    BOSSS3 Member
    119
    I need one of these! The flames are the way forward!:rockwoot:
  13. Wezcubbages3
    Wezcubbages3 New Member
    14
    Hi guys. These fit a Audi s3 8p manual? 2007? If so. Where can i get one !!??
  14. Adam.
    Adam. Meow.
    662
    34
  15. Wezcubbages3
    14
    The s3 is not listed in compatable vehicles?
  16. Adam.
    Adam. Meow.
    662
    34
    • VW GTI MkV 2.0T
