wot first?
S4twiggy May 19, 2009
  1. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    hopefully in the next few weeks i should be looking at gettin some rims, i think im gona get myself some 19' RS4 DTM's as ive always had a fondness for them but im not sure wot to do first, do i get the rims and slap em on my S4 and risk rolling round like an audi allroad or do i get some coilovers first? cant really afford both rite now as the credit crunch has got me by the balls and squeezing tight but after the rims i was goin to get coilovers but i dont want to roll around with my car lookin on stilts so which do you recommend first guys, rims? or coilovers?
    let me know wot you think cuz i seen an A4 the other day on big rims an not lowered an it looked *****.
  2. Drizz
    Drizz Project Plush
    681
    coilovers
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    The S4 is lower than the A4 and looks lower still thanks to the painted sideskirts.
    Chuck the wheels on!
  4. disley
    disley Member
    76
    coilovers all the way for me.
    the rims will make the car look better but the huge gap between the wheel and arch will let it down,
    Been down both roads in the past and now would allways lower first .
    BUT
    if you dont have the 19s on you wont know how low to set up the coillies so you will probably end up altering the ride hight again when the wheels go on.
    HHHHHHmmmmmmmmm decisions decisions..
  5. Geeman
    Geeman Low Life
    1,318
    It's a toughie.
    I was lucky enough to be able to do both at the same time.
    I'd be tempted to go the coilies route first though... standard S4 rims aren't that bad to be able to leave on for a while...
  6. twostrokepower
    twostrokepower Member
    131
    i would go for the coilovers will look too high on 19"s
  7. S4twiggy
    1,815
    9
    i was thinkin jus get the wheels on but i hate cars which have a huge gap in the arch. how much do yall think i can get a good set of 19 DTM's for? cuz if i can get a good set for tidy money then i mite juswait that bit longer an do both.
  8. BBSparky
    BBSparky Amateur Spanner Monkey
    25
    I had the 19's on my car for about a month before i fitted the coilover. Only reason i did it that way was because the wheels came up at a very good price otherwise i would have lowered it first as it did look pretty bad on the standard stilts!
  9. aragorn
    18,485
    855
    I'd probably spend the money on the suspension, unless your tyres are needing replaced very soon.
    I wouldnt be buying coilovers though, unless your planning on spending a grand+ and buying proper ones.
    For a road car, most cheap coilover kits just arent any use, they're far too stiff, the valving is completely wrong for the road and the springs are too hard. All this together means that while the car may SEEM to drive better (it wont roll as much), your mechanical limits of grip will have been reduced.
    If your primary goal is to wedge the car into the floor, without any consideration for handling then fine, but TBH you may as well just take a grinder to your standard springs, as it will probably handle better like that.
  10. S4twiggy
    1,815
    9
    im looking at H+R's to stick on it, im not in a rush to get my car the way i want it so if it takes an extra couple of weeks saving to get the best for my s4 then so be it, im not one of these to jus stick on whhels an ride around until i get coily's so if i do get the coilys ill be stickin them in the garage or in a room in the house to keep them dry until i get the rims then put them both on. either H+R or KW variant 2.
  11. stapo69
    stapo69 All hail the mighty quattro!
    969
    I'd do the supension 1st, get more joy out of the car that way, rather than just looks, I fitted my 19s for a day and then took em off until the suspension got here cos it looked like this:
    Not a good look!
  12. S4twiggy
    1,815
    9
    thats sealed it for me stapo, i wanted to see a noggy s4 on 19's that aint been lowered an thanks to your pics i will now get the coily's first. hopefully get them in the next few weeks.
  13. stapo69
    969
    It's ok running 19s on standard springs........ if you want to drive across fields!
