Worried about washing my car
S3 Paul Mar 22, 2010
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Ive always thought i was quite good at this detailing lark, That was until i decided that my s3 was over due a real good clean,
    I jetted off most of the loose dirt with a jet was and then washed it using the 2 bucket method with a white megs wash mit and dodo super natural shampoo,
    I then rinsed with a hose and dried the car down with an autoglym leather.
    Then i used dodo juice clay and lube to remove the dirty from the paint... i did this one panel at a time and used 4 bits of clay by the time i had done the whole car,
    The car was then pulled inside my unit to get on with the polishing work but when i set up the halogen lamps my life was the paint in a right old state!
    swirls , scratchs... you name it, it was there !
    So i called upon a good mate of mine to come and try and correct the problems...
    After many hours and just as many products and buffing heads the paint was looking good again, Happy days
    So we then added 2 coats of Autoglym SRP and 1 Coat of HDW ( time was marching on )
    The problem is im now afraid to clean the car! have i been doing something basicaly wrong all this time and will i end up messing the paint up again?
    Any help with highlighting what im doing wrong would be great !
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Most likely cause will be the drying process. Something that people in your position always fail to change :) (no offence :)). Having re-read that sentence, what I mean is people always look at the washing/polishing stages as to procedures being wrong; drying is usually overlooked. Sounded a bit mean the first post around!!
    The leather will be killing the paint work, sadly. Micro Fibre drying cloths are a must. Quick hint, now your car beads well (with the HD wax and prep shown above, it should!). Use an open hose over your car once finished as this will allow the water to run off the car, rather than stand and bead. THEN dry by pat drying with a microfibre towel. Personally, the following, but Rich will most likely have some good suggestions from their site as well;
    http://www.i4detailing.co.uk/acatalog/Miracle_Dryer.html
    http://www.i4detailing.co.uk/acatalog/I4D_Uber_Premium_Drying_Towel_1.html
    The use of some quick detailer (like Megs no16 Last Touch) is also quite useful to provide some lubrication between the towel and surface.
    HTH
    JD
  3. S3 Paul
    2,825
    107
    Thanks JD
    I did wonder if the leather was a good idea but its something i have always done.
  4. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    Grab a coffee and read this illustrated guide in full - it covers all of the areas where you are doing things right, but more importantly also picks up on the things you are definitely doing wrong. Whilst the focus is on methods, a few product suggestions are made too...
    How to safely wash and dry your car - an illustrated guide >
    :icon_thumright:
  5. S3 Paul
    2,825
    107
    A few of my friends have said to get a SONUS 'der wunder' drying towel and a Megs lambs wool wash mit,
    I have a megs drying towel but i always thought it felt rough, Is this normal? Should i be just "patting" the paint dry rather than wipingit?
    Is the megs wash mit as good as others out there?
    Im looking to get these items sorted as soon as possible realy.
  6. WX51TXR
    1,452
    14
    Both products mentioned are perfectly fine, but not as good as these beauties...
    PB Luxury Drying Towel >
    Easirider Lambswool Wash Mitt >
    We use these two products in our studio on a daily basis, and you've seen the kind of cars we look after and the standards we work to.
    The Meguiar's drying towel has always been a poor performer, and it is normal for them to feel rough and hard after only a few uses - note to Meguiar's; get this sorted!
    Finally, the guide I linked you to above recommends pat drying over wipe drying, and explains why...
    :sm4:
  7. JD09
    3,096
    46
    I agree on the PB towel, although there are some very similar products out there, so pick and choose.
    The washmitts have always been OK for me. I have also used the Swissvax Waschpudel which was excellent;
    http://www.swissvax.co.uk/products/wash-products.asp
  8. S3 Paul
    2,825
    107
    Well thanks for the responce,
    Ive just ordered the products from polished bliss...
    Heres to a swirl reduced future !
  9. JD09
    3,096
    46
    Good stuff, another 5% commission Rich will be paying me then . . .
