Worn wiper spring?
Lavis89 Oct 17, 2013
  1. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,920
    756
    Just put some new wipers on ready for the winter, thought my old one was shot because there was a big patch where the wiper arm attaches to the wiper itself that wasn't getting wiped, unfortunately i have the same problem with the new blades. Windscreen is nice and clean, gave it a good rub down with concentrated screen wash before i put the new blades on.
    My next guess would be that the spring is a bit old on the arm itself so not pressing down hard enough, anyone had this problem before? if so how easy (and expensive) is it to fix?
  2. jojo
    28,981
    3,626
    WD40 the spring and the joint of the arm near the scuttle, and move it up and down a few times should cure the problem.
  3. Lavis89
    1,920
    756
    Will give it a shot tonight, cheers!
  4. Lavis89
    1,920
    756
    WD40 didn't help unfortunately, and the car is currently undriveable in the rain due to the fact i can't see anything! got a couple of photos here to show the gap. I got the blades from GSF, not sure if it's the blades themselfs causing the problem though, i had the same problem with my old blades, thought they were just a bit worn but now i guess that wasn't the problem. Is it possible to buy new wiper arms (spring and all)?
  5. jojo
    28,981
    3,626
    Those gaps are very strange! It's not the arms at fault there, it's the wipers methinks.
  6. Lavis89
    1,920
    756
    anyone got a link to some that are proven for an A3? i had a set from halfords which had a gap (only on the drivers side though, these new ones have a gap on both) and now this set from GSF. Getting to be a bit of a pain.
  7. jojo
    28,981
    3,626
    Should just get genuine aero wipers instead of these makeshift ones, no issues at all. I also have a set of genuine ones on my Passat using Halfords aero replacement blades with no issues.
  8. s3mad_dude
    s3mad_dude Noggies ruuuule!
    619
    79
    Try standard wipers instead of those makeshift wannabe aeros. I'm sure your arms are fine....
    Keep your receipt and then take them back. At least you will know if your arms are at fault or not.
  9. Lavis89
    1,920
    756
    genuine as in bosch aerotwin? will have a looksy for some now. need to be able to drive :mad:
  10. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    I have the Bosch Aero upgrade on mine and they wipe fine.
    If you apply a little bit of pressure to the clip at the end of the arm, can you press the wipers against the screen?
    If you can it could be the springs are shot. After 10 years the metal might has lost its elasticity. New arms unless you can source some from a breaker or find replacement springs.
    Liam
  11. Lavis89
    1,920
    756
    yea when i press down on them they do sit on the screen quite a bit better. Going to try a set of genuine bosch ones tomorrow, if they're no better than going to have to look for some new arms :(
  12. aragorn
    18,577
    868
    No, not Bosch Aerotwin.
    STANDARD blades.
    If your going to change the arms, buy PROPER aero wiper arms.
