'Woosh' Noise gone noisier when changing gear, (video)
nathwoz89 Feb 15, 2013
  1. nathwoz89
    nathwoz89 New Member
    It's a 2.0L TDI, was fine earlier today and now suddenly just makes a massive woosh/owl noise when changing gears, and it the turbo noise seems to have gone at 2nd rev but sometimes the owl noise happens when you put the accelerator down.
    Also when starting up now it sounds like a 'crash' after its started up for a second
  2. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    How is the car running? It's just the diverter valve going off when you change gear realeasing pressure that the turbo has spooled up. It's normal to a certain extent where it has been know for a turbo to be on its way out, however from your description it's fine and the car isn't running with any dramas or fault codes.
  3. Bramley
    Bramley Member
    389
    19
    sounds normal to me
  4. nathwoz89
    Even if its gone alot noisier since last night? And when i start the car the engine suddenly seems to 'drop' after startup, hard to explain
  5. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    No diverter valve on a diesel.
  6. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    Hole in backbox?
  7. nathwoz89
    I just took it to a local garage and he wouldnt con me i dont think, dads friend.
    He asked me to rev it he checked under the bonnet and in engine and he said there was a leak, then said the turbo pipe was cracked, and needs a new one, which would cost around £100 ?
    15 February 2013 04:52 | Facebook
  8. nathwoz89
  9. nathwoz89
    Any feedback from what the guy said and the video?
  10. smurfworth
    smurfworth Well-Known Member Audi S3
    1,930
    542
    getting instantly louder could well be a cracked pipe, or hole on exhaust near the turbo. get it smoke tested to see if its leaking but i wouldnt worry about it tbh
  11. nathwoz89
    It was something to do with the intercooling pipe after all... strange
