Woodstock DAB54 with BOSE?
Skittler Mar 19, 2006
  1. Skittler
    Skittler Redlined
    136
    Is the Blaupunkt Woodstock DAB54 compatible with the latest A3 model, with BOSE system?
    If so, anyone have any pics/instructions about how to connect one up?
  2. AndyMac
    9,832
    45
    Yes no problem, in fact it even uses the stupid non standard mini ISO connector for the Bose amp.
    So in theory it should be plug & play, though you will need an antenna amp (if you want FM as well as DAB) and fascia adapter.
    You may also experience popping when you turn the unit on & off, which is normal on all Audi systems, but hopefully they've sorte this out since the 8L model.
    The trickiest part is fitting the Blaupunkt DAB aerial.
    You will lose the DIS for radio/CD and you may have to wire both 12v inputs to perm live as there is no remote on on 01+ Audi's, they all use the CANBUS.
