So the water meth kit is fitted and is tested and works correctly. This was just using water from the tap, not actually plumbed into the engine.
I have some distilled water and pure methonol on the way, which i will mix 50/50, but what i need to know is.
1. what tests/check do i need to perform when setting the PSI controls on the controller?
2. what logs using VCDS do i need to watch to make sure everything is safe and i wont bend any pistons or whatever.
PSI SETTINGS.
My full boost is logged at 1.5Bar (22psi) but im only getting around 1.3 max. So should i start off just adjusting the start value? or the final value?
NOTE: this is a progressive controller.
Any help would be greatly appreciated, in time i will be going back to rick to get it all mapped in but for now i just want it working.
Thanks.
The boost controller, which is located in my fuse box inside the cabin, but with enough slack to pull out and use if needed.
And the pump located at the lower front end of the car, directly next to the washer tank. note the horn being held on by tie wraps!
PSI SETTINGS.
Thanks.
