WMI Help needed. Lots of it please!
g60leigh Mar 1, 2013
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Double check the yellow wire is switched..
  2. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    As long as rain keeps off I'm gonna have a check of it all tonight.
  3. Loor
    Loor Member
    32
    Guys, why don't u use original window washer tank to do both things, wash windows and WMI:yes: And it has level sensor as well.
    Dont have to fit special tank for WMI, just fill your window washer tank more often and thats it, even OEM look stays.
  4. g60leigh
    1,674
    207
    Won't the meth destroy the window rubbers etc.
    And don't think screen wash would be great in the engine lol ;)
  5. Westy
    Westy Well-Known Member
    17,443
    1,105
    One guy did do this (Welly) but the AEM kit that most of us bought comes with a tank and personally I'd rather keep the two things seperate.
  6. Loor
    Loor Member
    32
    Screen wash liquid is same as just any other mixed methanol and water :) U can even choose how strong mix u wanna use, they even sell those 50% meth washer liquids in almost every gas station.
  7. g60leigh
    1,674
    207
    Didn't know that. Thought screen wash was ethanol rather than meth.
  8. g60leigh
    1,674
    207
    Well been out and re soldered all of the wiring.
    Also added a switch so I can isolate it if needed.
    Now all I need to do is figure a way of testing accurately when it is activating. I have the controller set to where I believe it needs to be. But would like to test it does activate when I want it to
    Any suggestions
    Also what water do you guys mix with the meth? Is it diionised or distilled. Of just tap?
  9. Westy
    17,443
    1,105
    I just use tap water but it will probably depend if you're in a hard water area or not.
  10. S3Alex
    10,854
    4,839
    I use the AEM kit on my car,running between 25-50% methanol.
    Methanol I get from my local model aircraft and car shop,at around £9 for 4L,which is pretty reasonable.
    I always use demineralised water.
  11. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    distilled water has more oxygen in it.
  12. s3dave
    10,110
    736
    Sorry but £9 for 4 litres is a rip off, i get 25 litres for £12 and i dont know them from adam!!
    OHH also i am from Yorkshire, so have the best water in the uk... so straight in it goes....:beerchug:
  13. g60leigh
    1,674
    207
    Demineralised? Where do you get that from?
    I have a source for the meth. So just got to get time to get it.
    How do you safely store it?
  14. superkarl
    9,610
    2,481
    Demineralized is deionized, much the same as distilled.
  15. S3Alex
    10,854
    4,839
    Absolutely.
    I've found Halfords sometimes sells 4L packs really cheap and just buy a few then.
  16. Westy
    17,443
    1,105
    I have my meth in a meth container in my garage but I'd rather keep it in a shed if I had one. If a fire was to brake out in my garage 25L of meth isn't going to help much!
  17. g60leigh
    1,674
    207
    Got some de-ionised water from asda this morning. 75p for 2.5L on sale so grabbed a few.
    Do you use any special container to store it in or just the 25L container it comes in?
    Will store it in my shed as that sounds the most sensible lol
  18. S3Alex
    10,854
    4,839
    I either keep it in the house or garage.
    Just not outside in winter!
    Good price there.
  19. g60leigh
    1,674
    207
    Out of curiosity. Why not outside in winter.
    Not got any yet or seen coshh label etc yet. But would of guessed it would be fine in cold just not hot areas.
  20. g60leigh
    1,674
    207
    Got Meth!
    Got some meth dropped off last night so tank is now filled ready to test.
    First real test will be on way home late tonight, but hopefully get a feel for it on way.
  21. Scullies
    Scullies Well-Known Member
    1,543
    658
    Do you have VCDS? Would be nice to see some IAT logging.
    I found a pump and its on its way :)
  22. Westy
    17,443
    1,105
    Have you fitted a solenoid to avoid syphoning? If not you want to keep an eye on it as im on my 3rd AEM nozzle as they are leaky cack!
  23. Scullies
    1,543
    658
    do you use a check valve Westy?
  24. Westy
    17,443
    1,105
    I do now. I use a devils own solenoid and it works a treat. Stops any syphoning of mixture into the FMIC pipes. I nearly wrecked my engine when half the tank had gone into the hoses and I turned the car on!
  25. Westy
    17,443
    1,105
    Well the AEM nozzles have in built check valves but I've had 2 fail in a few months so I just don't trust them.
  26. g60leigh
    1,674
    207
    I have two check valves on. No solenoid. (Yet possibly)
    I have an inline check valve and the one built into the nozzle.
    Do you think a solenoid is still necessary?
    Westy- how much was yours and where did you get it from.
  27. g60leigh
    1,674
    207
    Had it switched on for the journey to work. But traffic was awful so not had chance to feel if any difference yet.
    Finish at 23:30 tho so should get to open up a bit on the journey home.
  28. Westy
    17,443
    1,105
    You might be ok with an inline too. I was fonna get an inline but Bill said he'd used a Devils Own solenoid for years on his race car with no issues so I went for that. Don't think it was cheap, around £40 and something else to wire in. Just keep an eye on you level in the tank. Check it very frequently. If you suspect it's dropped a lot, don't start the car! Pop the FMIC hose off by the nozzle and see if it's full of water/meth.
  29. g60leigh
    1,674
    207
    Been running two days with just water and seems fine.
    Also checked all of it for leaks before and after fitting before switching it on.
    Hopefully it's all good.
    Will keep checking tho.
  30. Westy
    17,443
    1,105
    There was a bad batch of nozzles that AEM were aware of so thy might have sorted it. I seemed to have had 2 of them though lol
  31. g60leigh
    1,674
    207
    Once you have a bad experience tho. You loose confidence in the brand.
  32. Scullies
    1,543
    658
    s3dave likes this.
  33. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Leigh, use the check-valve from the first wmi kit you had if you still have it. Same as the one I had, never had any issue with it. just a simple design and more reliable than the AEM ones
  34. g60leigh
    1,674
    207
    That one wouldn't of worked. Aquarist uses a much smaller bore pipe work. 😒
    Shame tho as good price
