Wishbone ball joints.
ayfreetee Apr 24, 2011
  1. ayfreetee
    ayfreetee Well-Known Member
    1,455
    288
    Are wishbone ball joints a pain to change on an A3 1.8T?
  2. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    no not realy. there is 4 nuts that hold them on. 1 at top 3 at the bottom. undo the top one then get a ball joint splitter and seperate from the hub. undo the 3 underneath and its out.
    when i did mine i replaced the hole wishbone, they arn't exspensive from you'r local car shop.
  3. HTC
    HTC Active Member
    3,428
    9
    On the A3 it's a little bit more of a pain. As the ball joint sits closer to the driveshaft than on the S3, sometimes the you need to pull the drive shaft out of the wheel bearing housing if the top nut doesn't want to budge.
  4. ayfreetee
    1,455
    288
    Thanks for the replys chaps, the only reason I will change just the joint and not the whole arm, is that a new one came with the car.
  5. Westy
    Westy Well-Known Member
    17,443
    1,103
    Also get the ball joints from audi. Superkarl fitted euro car parts ones and had a few fitment issues. I bought audi ones and they went straight on.
  6. ayfreetee
    1,455
    288
    Jacked car up and took off the wheel to change the joint only to find that it looks like a new wishbone, so no need to fit the joint, result.
  7. Westy
    17,443
    1,103
    Lucky sod ;)
  8. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Just ordered my ball joints from audi will be fitting them this weekend.
