Wiring in facelift vents??
Oranoco May 25, 2009
  1. Oranoco
    Oranoco Well-Known Member
    3,974
    405
    Where do people tap into for the feed?
    I have my clocks out to make routing cables easier
  2. Broken Byzan
    13,237
    465
    Mine are taken from the ignition on feed. 75 X is it? or is it the 30 ?
    Whichever one is live ignition on
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    I'd splice into the wiring for the dash buttons so they only illuminate when you've got the sidelights on.
  4. aragorn
    18,491
    855
    75x is ignition live, but its then not controlled by the lights/central locking module as the rest of the illumination is.
    I'd splice it into the illumination for some of the other controls.
  5. Broken Byzan
    13,237
    465
    My dash lights with the ignition, hence why i went for that instead of the lighting circuit
