wiring in electrics?
BahnStormer77 Feb 20, 2009
  1. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    Where is the best point to splice off a spare power line?
    Previously, in my Mk3 Golf, I just used to pull out a non-essential fuse (interior lights, etc) and then stuff a stripped wire in the one side and then push the fuse back in (obviously making sure whatever I had wired in was also fused) and then I'd wire the ground to a grounding point on the metal structure under the dash (near the fuse box).
    I knwo this is hardly the "recommended route", but I was wanting to see what the recommended method for wiring in something on the Audi A4 would be. Anybody got any diagrams / how-to's that would point me in the right direction? I jsut need a few photo's to see where to get started.
    Preferably with a choice of "permanently "on and "ignition controlled" options? Although I can always work these out for myself...
    I'm looking to wire in a GPS/laser/radar camera detector (v low current) on the ignition controlled circuit and then also to mount cigarette socket and USB charger on the permanent circuit (yes, I know - can cause battery drain, but I'll probably put an in-line switch to limit the scope of this).
    Any help / links appreciated!
    edit: this is relation to my B6 A4 Quattro TDi.
  2. Issac Hunt
    1,162
    The fusebox.
  3. dunk
    dunk Member
    770
    you could test the feed to the cigarette lighter socket - i think its on with ignition off, and more convenient to get to than the fuse box, or failing that the power to the radio
  4. stevehall
    stevehall Member VCDS Map User
    300
    I used the cig feed and put a 4 port 12v sockets in my glove box. Only ever use them for low voltage things, phone charger, tom tom and things like that.
