Wiring help please...
mrmattholmes Sep 25, 2012
  1. mrmattholmes
    mrmattholmes New Member
    15
    Hey guys, got a 2000 A3 1.8T Quattro.
    The alarm doest work, neither does the remote central locking, so...
    Ive got an aftermarket alarm to fit...
    Ive fit a quite a few before but i dont have the wiring diagram for the A3 so could do with some help.
    I need wiring diagrams for; central locking, electric windows, indicators, ignition..
    Any help would be great.
  2. aragorn
    18,174
    770
    The stock alarm and RCL is controlled by the locking pump in the boot. the locks are all pneumatic so an aftermarket system isnt really going to work if the pumps dead.
    The windows and various other things like interior lighting also wont work properly without the stock locking pump...
    Your far better off just properly fixing whats broken. You can buy replacement pumps on ebay for around £50.
  3. mrmattholmes
    15
    the central locking works, just not from the remote..
    everything is fine with the alarm just the siren doesnt work, id rather fit an after market alarm as the standard one is useless even if working.
  4. slowcoach3
    slowcoach3 Active Member
    835
    105
    43
    Sounds stupid but have you put a new battery in the remote? That fixed the problem for me when mine didn't work
  5. mrmattholmes
    15
    yeah tried the battery..
    id rather fit the new alarm because the standard one is useless and is no where near loud enough
  6. aragorn
    18,174
    770
    Move the standard siern to under the bonnet and it'll be much louder. Get one off ebay from a newer Audi as they revised the design.
    Remote key probably just needs matched with the pump again.
  7. BtownA3
    BtownA3 Member
    74
    I just did this - Will dig out the wiring when this wet stuff stops falling out the sky
  8. mrmattholmes
    15
    cheers mate, much appreciated
  9. BtownA3
    BtownA3 Member
    74
    Ok so for the remote central locking - Assuming the pumps are the same you need
    Audi Side
    There are 3 plugs that go to the central locking Pump.
    Power Plug = Self explanatory
    Black Plug = Has the Close signal wire
    Brown Plug = Has the Open Signal wire
    Power plug (haven't documented the colour, but has unique cable colours to identify)
    12v+ = RED/BLACK 10A general fused supply - your unit has a de-rated fuse
    12v- = Brown
    Black Plug Close
    Red/Brown cable - note* watch out there is a Brown/red cable also on the same plug!!!!!
    Brown Plug Open
    Grey cable
    ^^ Praise goes to A3steve^^ - I used this with my Hawk Kit and it all works fine - I used ScothLocks to connect it up, The pump can be a bit of a ***** to get out, also make sure you put the sound proofing back around it as it is one noisy bit of kit
    Hope this helps
  10. mrmattholmes
    15
    Cheers mate, any chance u can remember if its triggered by a live or earth on the lock and unlock? Got all the alarm wired apart from central locking
  11. BtownA3
    BtownA3 Member
    74
    Negative switched off the top of my head - will pull out some paperwork and double check though
  12. mrmattholmes
    15
    Cheers mate :)
