wiring diagram
2.8 30v Oct 15, 2013
  1. 2.8 30v
    2.8 30v Member
    149
    19
    can anyone help me Iam after the wiring diagram for the brake light system for a 1997 2.8 Quattro avant I can't seem to find one any where
  2. aragorn
    18,369
    828
    What are you wanting to know?
  3. 2.8 30v
    2.8 30v Member
    149
    19
    when I got the car the brake light bulb warning light was on but all the brake lights worked ok.When I started looking into I found that the high level brake light has been wired to the n/s brake light,if I remove the o/s bulb the warning light goes out when I've disconnected the high level light its not working and I've got no power to it I've removed the rear 1/4 trim and checked the wiring from the multi plug to the light with a power probe that's ok so no broken wires in the tailgate.So need to find out if its a broken wire some were and why j have no power to it Just wanting to put the light out if its goin to be a mare of a job, as its poss an mot failure
  4. 2.8 30v
    2.8 30v Member
    149
    19
    I take it no one can help me on were to get a wiring diagram for the brake lights
  5. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    Centre brake lights isnt a mot failure as not all cars have them
    So are you not getting power to the rear brake light? Have you traced them wires back to any connections. What do you get there?
    Have you checked the earth of the rear brake. Could be an earth rather then a live
    Does a hyanes manual not show the rear light wiring diagrams?
  6. boost-addict
    1,000
    39
  7. aragorn
    18,369
    828
    thats for a B6 though, so it wont be quite the same.
    I've got the diagrams at home but i'm at work today so i cant help you just now.
  8. boost-addict
    1,000
    39
    Oh. Says a4 b5
    But says 2002 my on the diagram!!
  9. 2.8 30v
    2.8 30v Member
    149
    19
    Cheers for that, i don't have a hyanes,i think the warning light is a mot failure, ive checked the multi plug in the n/s/r 1/4 panel now power to that ive powered the loom up from there and the light works so i need a diagram so i can check the wiring at anyother multiplugs and find were the earth points are
