Wiring diagram for 1997 A4 Central Locking Pump?
clfletch Apr 2, 2007
  1. clfletch
    clfletch New Member
    9
    I'm fitting a "Rightclick" Remote central locking system off Ebay - but don't know what colours the "open" and "close" wires are coming out of the Audi pump. Any ideas?
  2. inigoj
    inigoj Member
    263
    I have just fitted a 'Rightclick' central locking kit to my 97 A4, the open and close wires in the pump loom were:
    Open = grey/white
    Close = red/brown (late 'R' reg 97 may also be brown/grey)
  3. clfletch
    clfletch New Member
    9
    Thanks - was yours the "pneumatic" or the "type 2 ground driven" type? Mines got two pipes coming out of the back - one for the boot and another for the doors.
  4. inigoj
    inigoj Member
    263
    It is 'type 2 ground driven', i also have an 8LO pump with 2 vacuum connectors so your wiring loom should be more or less identical to mine.
  5. clfletch
    clfletch New Member
    9
    Thanks a million - its working! I'm trying to sort out the auto window wind-up and the separate boot lock - can you tell me what colour those are, and which plug they go into?
  6. inigoj
    inigoj Member
    263
    For windows 'full closure' the green wire on the rightclick box connects to the red/brown wire in the pump loom, i think its in the outside white connector.
    (Big thanks to truebrummie, who helped me with the same problem)
    I didnt connect the boot unlock or release on my saloon (no release). I'm not sure if it is vacuum or electrically controlled on a B5 saloon.
    If there is a control wire from the pump, or maybe wired directly to boot lock electrics, connect:
    Pink wire from rightclick box if it has a negative trigger.
    Red/black from rightclick box if it has a positive trigger.
