Wipers squeaking, banging. ARE they right ones?
krisavant Apr 21, 2013
  1. krisavant
    krisavant Active Member
    449
    61
    Since I've had car (1 year) the wipers has never run smooth across the windscreen.
    The ones that were on there when I bought the car were retrofit and were rubbish so replaced with Bosch retro fit but were still awfull, then tried Valeo and still same outcome.
    They all clear the rain fine but squeak, judder and sometimes bang.
    Anyone any ideas??
    I'm thinking I need to go back to the old style 'conventional' wipers and not 'retrofit'??
  2. Az
    Az Hard slammed!
    1,023
    34
    The squeaking could be the spring inside the wiper arm, try lubricating it with some wd40 (obviously not getting any on the windscreen itself) mine was squeaking big time and it was well annoying (I have the B7 aero wipers as well) the knocking could be it hitting the A pillar when it's in motion, if it is that then the wiper arm will need to be removed and moved down towards the scuttle panel by a few teeth on the spline where the wiper arm bolts on to, this should stop the wiper arm just short of hitting the A pillar when in motion then.
  3. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Like Az says, my aero wipers were catching the A pillar on the drivers side. It was rubbing the plastic trim on the pillar and appeared to have coated the windscreen with a plastic film. Adjusted like Az describes and a couple of goes with some glass polish sorted it.
  4. krisavant
    449
    61
    The banging is the wiper bouncing on the windscreen. Sorry should have made that more clear.
    The wipers sit perfect and don't hit the pillar.
    I've got rain x on there also.
    The wipers just won't glide, even in heavy rain.
    Will the b7 aero wipers be a direct fit or do i need the arms?
  5. archemist
    archemist Active Member VCDS Map User Audi S3 Team Brilliant Black
    247
    31
    wipers can bang when the pivot on the arm goes (wears at the blade end) they effectively flick from one direction to t'other at the end of travel and you get the 'bang' noise - the only cure is new arms if that's the case. The mech wears too under the scuttle panel.
    b7 arms a straight swap (if you can get the old ones off ok) the part numbers are in the sticky and i got mine from a stealer for about £67 for arms and £21 for the two aero-blades
  6. robotplant
    robotplant Member
    154
    You will need to by the arms as well.
  7. krisavant
    449
    61
    The passenger side wiper on the arm is a bit wobbly, but thought that was the norm.
    New b7 arms it is then!
    Thanks guys!!
    Means we're on the wiper subject...
    Is there another style 'rear' wiper out there to replace the chunky one for the back screen??
    E.g golf mk6 rear wiper etc... Or something as slim line as those?
  8. Audi Doodah
    377
    35
    I believe the "slimmest" option is to remove and blank :laugh:
  9. krisavant
    449
    61
    Tempted, very tempted!
    If there is no slim line type I will.
    Gonna look into the new Avants & passats first to see what rear wipers they have, taking measurements and spray pattern first into consideration.
  10. archemist
    247
    31
  11. krisavant
    449
    61
    Thanks! Will be purchasing that!! 😉
  12. quattrojames
    14,050
    578
  13. krisavant
    449
    61
    Doh!!!
    I fitted a polo rear wiper to my fabia vrs, could have swapped them over before I sold car!!!
  14. krisavant
    449
    61
    Squeaking, juddering, banging wipers sorted!!
    Pinched the end of the wiper arm with pliers so it grips the wiper blade better and gives it a tight snug fit.
    Now wiper doesn't wobble around/judder going across windscreen.
    Temperamental? We'll see.
    Don't think rain x is helping with the glide either...
  15. Mike_B
    Mike_B Active Member
    533
    47
    Lovely - but, B7 arms and aero blades are SOOOOOOOO much better!
  16. krisavant
    449
    61
    They're still on my list. Lol
