Wipers - Rest
L60N Mar 16, 2008
  1. L60N
    L60N Guest
    Whats with the A3 wipers??
    If i have it set to normal, if i flick it once, it rests with the left blade in view, if i flick it again; it rests out of sight! LoL
    If i have it in auto sensing, it never rests out of sight (am i being picky?) LoL
    Also, the bloody arm rest: If i put it to the bottom where its most comfortable thats great, as soon as i apply the handbrake, it nudges it up just enough to be slightly annoying LoL.
    Apart from that, Im happy.
  2. Matt
    Matt Active Member
    1,404
    Not noticed about the wipers. I have the arm rest set so its just high enough not to clash with the handbrake
  3. h5djr
    9,399
    1,736
    I've noticed on mine that if they stop slightly above the lowerest position, if I leave them alone, they will move down after a couple of minutes.
  4. newbiecrg
    newbiecrg windsurfer
    1,328
    The arm rest is a design flaw that really bothers me, specially as my handbrake lever has leather trim... in the beginning I wasn't aware of that and there are markings in the leather trim already... Now I am very careful and never happens but it is a not a nice thing. They should either allow room for the handbrake or not allow the arme rest to go that low...
    Pedro
  5. mcc49
    mcc49 Stalled
    249
    The Audi wiper blades rests in different position every alternating wipe I was told by the salesman, it prolongs the life of the blade apparently by not having it resting in the same bent position all the time.
  6. h5djr
    9,399
    1,736
    I only ever use my armrest when I parked for a while. I always have it in the vertical position when I'm driving so I don't notice the problem. I mainly use to store my PDA Sat/Nav out of sight when I leave my car parked and don't want to take it with me.
  7. h5djr
    9,399
    1,736
    Here is the diagram from the workshop manual showing the correct park positions for the wipers.
    Dimension A should be 0-10mm and Dimension B 10-20mm.
  8. L60N
    L60N Guest
    Well in reply to that, i'd say, that theres 10mm+ difference between both of my alternating resting positions LOL!
    Ah well, its not tooo annoying.....
    Wait on, what am i on about?? When i do the wipers, if its not resting out of sight, i give it another flick so it does. :tocktock: :nyah:
  9. PeterS
    PeterS Member
    56
    15
    That was my understanding as well, but it can be slighty annying sometimes when it appears that the wipers aren't properly parked...
    Peter
  10. rich1068
    rich1068 Member
    674
    Never mind how they park. What about the fact that they only 'go' again after the car sets off? ie raining, wipers on, park up, leave car. Return to car, start engine, no wipers until you set off. If your windscreen isn't clear you have to turn the wipers off and then on again before it's safe to drive off. It's a niggle but there you go.
  11. qstix
    qstix New Member
    26
    Asfor the arm rest, why don't you just get you hand brake adjusted, so there isn't so much travel on the up position, surely thats possible..
  12. L60N
    L60N Guest
    As said, its a minor niggle, and i KNEW someone was going to say get the cable tensioned, but its not even slack. Its Virgin tight :p
  13. newbiecrg
    1,328
    like I said... design flaw...
    Pedro
  14. L60N
    L60N Guest
    Exactly.
  15. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    C'mon - you really complaining about having to move a finger?
  16. bacardi
    bacardi Active Member
    1,139
    i think this auto off feature is a bit pants too, sure it may be a good idea to save the wiper blade but its bloody dangerous
    In all the cars I've owned, if the wiper stalk is in any of the on positions (intermediate, slow/fast etc) when you turn the engine on it wipes the windscreen
    not in the A3, it waits till you start moving again
    It also stops wiping the windscreen when you pull up at a roundabout
    Hissing down with rain, looking for a gap in the traffic, you need the wipers to stay on!!!
  17. L60N
    L60N Guest
    On the contrary,
    My old cars auto wipers used to do that; single wipe on startup, what ever the weather.
    I used to grimace as it ground the dry windscreen :sadlike:
  18. bacardi
    1,139
    On the contrary to what?
    Mine aren't auto wipers and don't do a single wipe on startup whatever the weather,
    I'm referring to whatever position you leave the stalk in, the car decides if its going to wipe the screen or not
    imagine this scenario
    get out of the car one evening after driving home in the rain, so you leave the wipers on
    now you get up in the morning and its still raining,
    you walk to the car, start it up, wipers stay put
    until you start moving
    pointless
    now also imagine, you're trying to negotiate a roundabout in the rain
    you pull up, trying to spot your gap
    the car decides it doesnt need to have the wipers running
    its a pointless and dangerous feature
  19. Kontraband
    Kontraband Active Member
    2,001
    the last car I had I had to press the button on the stalk to get the auto wipers on. When I saw that the audi auto wipers was on the upshift of the stalk I was well happy.
    Seems thought that it may not be all that good, although no problems really...
  20. newbiecrg
    1,328
    I didn't spec auto wipers because it is a feature I like to have absolute control.... like auto headlights... for me if they are not standard I will never bother to spec them...
    Pedro
  21. h5djr
    9,399
    1,736
    According to the current Owners Manual...
    If you stop briefly, e.g. at traffic lights, the wiper speed will automatically be reduced by one level.
    So I assume from that, if they are on max speed they will go to normal speed, normal speed to intermittent, intermittent to off. Not sure if that applies to all wipers or just auto-sensing wipers.
    Personally I'm not a great fan of the auto-wipers, but I did want auto-lights, and the two go together. Auto-lights is very useful when the road has lots on tunnels, such as when I'm on holiday in parts of Germany and Austria and Switzerland where you are required by law to turn on your headlights in tunnels. Generally I'd be happy with just the normal intermittent.
  22. L60N
    L60N Guest
    Seems pretty sensible to me.
    And if you think not, move your FAT arm and do it yourself lol
  23. Kontraband
    2,001
    yeah, the auto wipers just slow down... not moving so fast means you don't need the wipers batting away when your stationary.
    I am completely opposite to you Pedro and wouldn't not spec this feature now, I love it.
  24. bacardi
    1,139
    Absolutely
    Perhaps I wasn't clear, Mine aren't auto wipers, they are bog standard ones and they don't give you control
  25. bacardi
    1,139
    Me too, normal intermittent would be fine, its the turning off that annoys me, its a small niggle though, I usually put them on the fast speed setting when approaching roundabouts in the wet so I don't suffer this
  26. bacardi
    1,139
    seems sensible for the wipers (NON AUTO)to stop when its raining?
    What?
  27. Matt
    Matt Active Member
    1,404
    I dont have auto wipers but mine does the same. I personally find it a good feature as there quite often isn't enough water on the screen at standstill to need it on the same speed so the next speed down works well.
    Re: the wipers not coming on when starting up if already turned on - I always turn them off when I leave the car just out of habit so I obviously have to turn them back on again if needed so no problem with them not coming on. Its only because it used to really bug me with previous cars if I had left the wipers on and it was dry when I next used it, the wipers would come on and smear the screen so got into the habit of always switching off the wipers to avoid that happening.
    I can see how it would be annoying if you didn't turn them off everytime though!
  28. L60N
    L60N Guest
    Its strange, the second day i drove for maybe 3-4 hours in the rain-drizzle, and not once was I put in that situation, nor do i recollect (at any point) thinking woa ****, my wipers have stopped working, and they were on auto the whole time. :D
  29. bacardi
    1,139
    Perhaps that's because you have auto wipers and I don't?
    Mine aren't auto wipers and stop wiping when the car stops moving, or wasn't that clear?
    Perhaps its a good sales feature from Audi
    "if you don't want your wipers to stop wiping when your car stops moving, please give us some more money for auto wipers"
  30. h5djr
    9,399
    1,736
    Which setting are they on when they stop. As I understand it and I think it was like that on my previous A3s which did not have auto-wipers, the wipers will only stop if they are on the intermittent setting. If the are on any other setting they will go to the next slowest setting. Am I right?
  31. sleep envy
    sleep envy Member
    253
    TBH if on A Road or M-way I always have dipped lights on as it makes the numpties and dawdlers more aware
  32. L60N
    L60N Guest
    When i use my auto wipers, they are amazing.
  33. Savage
    Savage Savage
    68
    Sounds like you're either on an intermittent setting or there's a problem with your wipers. When I come to a stop at a roundabout or junction and when in the constant on position my non-auto wipers move to the intermittent setting (i.e. they don't stop, they just wipe every 2 seconds or so).
    Also I never have the problem of returning to the car and the wipers not working because when I leave it I turn them off, regardless of whether it's pissing down outside. It's just a routine thing I've always done. I think it comes from many years of driving cars where if you got out of the car with the wipers on it left them in the middle of the screen, unless of course you timed it right.
  34. Matt
    Matt Active Member
    1,404
    Yes thats right. Which ever speed they are on when you are moving they go to the next speed down when you stop. I think even when you have them on intermittent and you stop they dont go off completely, just go to the lowest speed setting unless you are already on the lowest setting in which case there cant be much rain about anyway! Cant fully remember off the top of my head if thats right or not, pretty sure it is.
  35. bacardi
    1,139
    Not noticed TBH, I'll check on the way home, I seem to remember it happening on slow speed and them stopping for 4-5 seconds then wiping
  36. PNH80
    PNH80 Low life livin' the high life.
    1,633
    I've noticed this also, i was wondering if it was a fault but apparently it's designed that way so not to worry... I purposely didn't want an A3 with auto rain sensors because i don't trust them and lets be honest, i have eyes, and when i see rain i switch the wipers on. Not rocket science. I also didn't want an armrest...what's the point? It's not a lazy automatic motorway cruiser so the armrest just gets in the way in my opinion.
    Options like this i'd expect in an executive saloon but are a bit unnecessary in an A3.
  37. bacardi
    1,139
    I quite like the arm rest, gives me somthing to lean on when stuck in the miles of stationary traffic
  38. newbiecrg
    1,328
    me too and quite handy to store my wallet and other bits while driving...
    Pedro
  39. h5djr
    9,399
    1,736
    I suppose, with the A3, you have the best of both worlds. I usually have mine in the vertical position most of the time as I don't use it when I'm driving. But as you say, it can be quite useful when your stopped or stuck in traffic, in which case it can be simply put into the horizontal position.
    Perhaps the next A3 will have the electrically operated handbrake so there will be no problem with it getting in the way of the handbrake.
  40. bacardi
    1,139
    I can see how people would have issues with the handbrake but I've got my arm rest set to "rest" on the handbrake lever when its up, so I have no issues with applying or taking off the handbrake with the arm rest down
