Wipers Not parking
patchelect Mar 15, 2010
  1. patchelect
    patchelect New Member
    10
    Yesterday while driving in the rain using the intermittent feature, my wipers suddenly decided that the park position was almost straight vertical! I thought I heard a click as it happened but can't be certain. As we continued on our merry way they began getting closer and closer to the correct position and currently are almost all the way back. Is there anything I can do, adjust, kick?
  2. quattrojames
    14,050
    576
    Maybe the wiper mechanism seizing up? Or a relay fault?
  3. patchelect
    10
  4. basspower
    basspower Member
    64
    i has this prob turned out i needed a new wiper motor.
  5. polar
    polar Member
    86
    Had problem last week. My wipers stop in the wrong position because the motor cut out due the wiper linkage seizing up. A very common problem.
    If you can get the wipers moving get some "Plus Gas" Penetrating lubricant. You can use WD40 it is not as good at penetrating but will still work.
    Take off the black cover, covering the battery and wiper mechanism. Using the Supplied red straw that comes with the spray. soak the linkage ends. Not just the linkaqe parts that attach to the wipers but also the connections behind.
    If the wipers are very stiff then give a helping hand by lightly helping the wipers. They will free up and move correctly.
    Mine took two days to get moving properly and now after a good soaking every day the blades are working correctly even on full speed.
  6. scott b
    scott b Active Member VCDS Map User
    1,254
    well ive just replaced the linkage, all working spot on now but what a **** job to do,
    and any one know how much the plastic scuttle panel trims are, i got a bit frustrated with it lol
