Wipers - mucked up positioning!! Help!
stephanbegley Dec 18, 2010
  1. stephanbegley
    stephanbegley New Member
    22
    Guys -
    The snow has shafted the drivers side wiper - its basically sitting 3-4" higher on the windscreen than before - so when i switch it on it goes over the side of the window edge!
    Is there any way to reset the wiper position?
    Thanks!
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    46
    Take off the wiper arm and refit it slightly lower. Sounds like you may have chewed up the splines on the wiper arm shaft.
  3. loftylad
    loftylad FinishedWaitingForMyAudi :)
    I stand to be corrected, but it sounds like its moved on it's splines. It might be that you can remove and replace the arm to sit correctly(usually removal of a hex nut), or the splines may be "rounded" and you'll have to replace the arm (or the shaft it sits on)
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    It will be the arm if spinning on shaft, its a softer metal so it goes before shaft.
  5. JoolsS3
    JoolsS3 New Member
    14
    I've had the same issues mate. Just clear all the ice and snow away from your screen, reposition the wiper with your hand and it should sort itself out - it did for me anyway!
  6. tonz
    tonz New Member
    19
    yeah, I have the same issue. the right wiper arm is being overlapped by the left arm so the drivers side of the windscreen is not getting cleaned. im not sure how to fix this any ideas?
  7. mike foster
    3,967
    Don't blame the snow mate - moral of the story is never ever use wipers to clear snow !
  8. audicruiser
    audicruiser Audi Heaven
    1,865
    +1... clear snow on the screen and put them to service position to clear the snow from where they park...
  9. Mick a3
    Mick a3 Mellow Yellow
    266
    when i had my whole wiper linkage out it took about 6 or 7 try's to get the perfect again, then I noticed 2 blue lines drawn by pen on it indicting the correct starting position.
  10. paddy
    paddy Audi=No fault code, no idea
    5,184
    137
    Dont forget that where they stop in use and where they park are diffent when re setting.
