winter tyres
knoxie Nov 1, 2011
  1. knoxie
    knoxie K4OXE
    619
    15
    rightyho chapies and chapets im looking for a decent daily use winter tyre for standard 02 plate s3 wheels?
    when i bought it about two weeks ago it came with 'triangle' tyres :s
    they seemed ok at first tbh but at the weekend in one of the big downpours it turns out they are pants!!! haha
    much love knoxie
  2. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Falken FK452`s are a good tyre for the money not sure if they are designed for winter but i run mine all year round
  3. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    Khumo I'zen's are F**king awesome in the snow! & worth every penny if you want just winter treads. Anything below 5˚c & they will amaze you!
    I might add that they can be a little "dangerous" if you forget about the difference in normal conditions, again anything above 5 & they seem to be a little soft & squidgy to the point where I've crossed the road on 1 corner where it would have stuck like glue with F1's on.
    Imagine a corner on a stretch of road you know well. on a normal day, wet or dry with say eagle F1's or Toyo Proxes on you could easily take at 70-80. Try the same with the winter treads on & you would probably come close to the verge on the wrong side of the road...
    That same corner covered in snow you would be reduced to 30-40 with normal tyres. With the winter boots on, 60 easy.
    Stopping distances are also hugely different as we tested. Side by side, same car at 20mph & my mate took 2 full car lengths more to stop. Now imagine that at 40-60mph...
  4. beanoir
    beanoir Large Member
    2,171
    31
    If you're looking for a proper winter tyre that you will only use for the winter months then have a look at the Dunlop Wintersport 4D.
    I fitted a set to some 16" TT wheels which I swap over to for the winter.
    If you want some cheaper options then try the Kleber range of winter tyres, I hear they are quite good.
    Don't be tempted to buy "all-season" tyres, they are no good in the winter or in the summer.
  5. ive just bought a set of nankang snow sv-2, dirt cheap. not run them yet but the reviews are good and when comparing to continental winters no real difference in compound or tread. no idea if they will fit the s3 though, ive gone cheeky on my 1.8t and bought some 15" seat leon alloys then sprayed them black to hide the corrosion.
  6. aragorn
    18,665
    880
    The problem with cheap winters is they're often great in the snow, but ****e on wet roads. And unfortunately in this country you'll spend most of winter driving on cold wet roads.
    The dunlop Wintersport 4D's, Contis TS830 and Goodyear UltraGrip 8 are all excellent options. Have a look on tyrereviews.co.uk at the "GROUP TESTS" for more.
  7. veru true, i used that site when picking tyres - its not as good as conti and goodyear etc but its not bad and loads cheaper, im not planning on driving like i stole it this winter - ive made the mistake of thinking im Hannu Mikkola before!
  8. liquids3
    liquids3 Member
    930
    22
    I would'nt bother whats the point in buying winter tyres for two weeks of bad weather!,cost you £300 (there **** in hot or wet weather),and no one can drive on ice!,you'll want to change them by the spring another £300,if you want all round tyres that won't give you road noise less grip in nomal weather,look at the new bridgstone all weather tyre!,if not lower your tyre pressures for the bad weather and take it steady!!
  9. beanoir
    2,171
    31
    I used to have the same attitude as you towards winter tyres in fairness, but after having them fitted on a couple of my cars i'm now stuck on them for good.
    A common misconception is that winter tyres are just designed to work better on snow, the truth is they are designed to outperform summer tyres (or what we all call normal tyres) in temperatures below about 7c and in ice and wet weather also. When you consider that about 3-4 months of the year in the UK will see average temperatures below 7c then it goes without saying that winter tyres are the better choice.
    Cost wise its a judgement call, I accept they are not cheap, but the cost can be offset to some degree against the wear you save on your summer tyres in that period. The other cost to consider is the cost of damage to your car from having an accident in the snow or ice etc, it only takes a slight slip in the snow to bend a rim on a curb and there's the cost of your winter tyres.
    If you live in a remote area, and have to drive to get to work or else, and prefer the extra safety in the cold winter months then they are well worth it IMO. Once you've driven on winter tyres you realise their benefits, and thats a benefit i'd not be without now.
  10. ^ I agree.
    I am self employed so if i dont get to work then im not getting paid! not worth the risk or risking your car, i think its about this country looked at the rest of europe - its the law to have winter tyres in germany, as a result the country doesnt grind to a halt at the first sight of snow!
  11. aragorn
    18,665
    880
    Yeh, spare set of scruffy cheap rims off ebay for the winters and you can swap them out come spring.
    The cost is more or less offset by the reduction in wear on your summer tyres.
    Unfortunately the UK winters are somewhat milder than you see across a lot of europe, which is why a lot of people here find it difficult to accept they should equip their cars appropriately come winter.
    I baught a Set of Dunlop Wintersport 3D's last year from german ebay. They were all nearly new with 7mm of tread and i saved a fair bit of cash over buying new. Unfortunately you need to be patient and spend hours raking thru adverts in german to find some that are actually worth buying. A lot of germans seem to ditch the tyres when they get down to 4mm as they become useless in the snow much below that, but then theres little point buying ones with only 4mm on them and ebay is swimming with them!
  12. liquids3
    liquids3 Member
    930
    22
    Yea true just which ever tyre you put on will not work on ice!,normaly when it snows you can drive slowley in it,next day its ice and your stuffed!,everyones open to there own opinions though!
  13. liquids3
    liquids3 Member
    930
    22
    cost effective and worth it i agree!,just don't agree with people that think that you keep them an all year,for one months snow!
  14. beanoir
    2,171
    31
    lol, it's not opinions, its fact!
    Audi Winter Tyres and Winter Driving - YouTube.flv - YouTube
  15. aragorn
    18,665
    880
    You dont keep them on all year, they'd wear like mad if you left em on when it got warmer.
    Mine will go on once the average temp drops below 7c. Its not quite there yet, although it has dropped below 7 a couple times the average is holding somewhere around 10-12 still. Then they'll come back off once it climbs above 7 again.
    Last year they went on some time in late november and came off late february if i remember correctly.
    You'd be surprised just how much traction you would actually have on ice with a good set of winter tyres, especially on a quattro car.
  16. liquids3
    liquids3 Member
    930
    22
    Yea but as the first post,dose he want new tyres for the year or winter months,had a freind that had winter tyres on,in may and kept loseing the back end of the car!,winter only your right!,not only wear (grip) in normal weather!,is england that bad?
  17. liquids3
    liquids3 Member
    930
    22
  18. beanoir
    2,171
    31
    Did you even watch that video, it was shot in an ICE rink...!?
  19. colicabcadam
    colicabcadam Guest
    instead of spending £300 quid - i'd rather just drive that little bit slower and safer....
  20. liquids3
    liquids3 Member
    930
    22
    Yea but states its better but won't stop you,you will still slide!,and its a sales video!,looks like they are taking the corner at different speeds!,theres another video i watched after with qwinton wilson,and they put and auto 6 series against a 1series manual deisel,to sale winter tyres obveously a 6 series auto won't move!
  21. aragorn
    18,665
    880
    It will if it had the correct tyres fitted ;)
    TBH you need to try them, this country has it burned into their brains that you cant drive on snow/ice.
    This is what happens when you have 4wd and proper winter tyres:
    Subaru Impreza Pulls Truck Out of The Snow - YouTube
  22. liquids3
    liquids3 Member
    930
    22
    You can't get winter tyres for a 6series so was'nt a fair test to start with!,yea don't get me wrong winter tyres are a good idea in countrys where there is snow for 5 months,but not over hear one week or two,i think its a waist of money!,and like i said if the snow freeze's for two days i would'nt want to think i can drive normaly because i have snow tyres!,why not use snow socks to get onto main roads when its snowing!
  23. Jason.s
    Jason.s Active Member
    2,879
    348
    As said winter tyres are effective from 7c on dry roads.. so it doesnt matter if its snowy or icey..they`re still going to be better than a normal road tyre in lower temperatures and once we get into mid november its going to stay around that level until atleast feb so they`re worth it really.
    I have a set of brand new Golf R 18" wheels with Conti winter tyres, 5 of them that a customer has just bought from us to put on his brand new Golf R. Cost him £3700 which he thought was a good price!! he`s having them fitted tomorrow, i said its not quite cold enough in the day for them and he`ll end up ripping them to shreds but he`s having them done anyway but wont be too long before its that cold every day.
    The downside of them is the limited tyre sizes yeah, i`ve had loads of customers ring up and want quotes on winter tyres but most of them are odd sizes which i simply cant get from any of my suppliers. Can either get smaller hatchback sizes like 15s/16s or huge 4x4 sized tyres but hardly anything in the middle ground.
  24. aragorn
    18,665
    880
    Mine are 225/45r17, and theres plenty of choice online in that size.
    I tried local garages and they could only really get me cheap and nasty budget winters. I had a moan at the guy at my local MOT station about it and he said they hardly sell anything other than budget tyres, summer or winter, and most of the cars he sees for MOT's are also running cheap tat.
    Kinda worrying really to think nearly every car you see is running on **** tyres, as most budgets are bloody lethal in the wet.
  25. Jason.s
    2,879
    348
    Most of the smaller cars that come in wanting tyres we`ll fit firestone/uniroyal and the bigger hatches and saloons we`ll fit conti/pirelli unless the customer wants something specific that they`ve fitted themselves previously.
  26. aragorn
    18,665
    880
    yeh, but i guess being a main dealer your seeing a different type/age of owner/car than folk who would use some of the normal small garages around here.
  27. Jason.s
    2,879
    348
    Yeah a lot of the smaller garages i deliver too i`ve noticed the tyres they stock are all budgets and look asthough they`ve been sitting there for years.
  28. beanoir
    2,171
    31
    One question, have you ever had winter tyres fitted to your car?
  29. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,306
    375
    LiquidS3, I think you have mistaken an excalmation mark (!) for a full stop (.). Or are you attempting to shout? Why is your opinion so strong against winter tyres and addamant that they don't work on ice?
    Has anyone tried Vredestein Wintrac Extreme tyres?
  30. liquids3
    liquids3 Member
    930
    22
    No they are great,just don't think are winters are that bad to spend £400 on tyres and £200 on wheels for a week of really bad weather!,rather lower the pressure's,and if its black ice not risk crashing car!,certain roads dose'nt matter what tyres you have you wont stop very easy,mayby better than normal tyres (but won't stop),so is £700 really worth it!,last winter there wer landrovers getting stuck,my mate had a 106 with 155,70,13 tyres on with lower tyre pressure and never got stuck,small width tyres with low pressures worked and it was way below 7c!!
  31. icenutter
    icenutter Member
    596
    One word. Awesome.
    I has some Snowtracs, then Wintrac Extremes, the Wintracs were much more of a 'all round' winter tyre, with much more grip than summer tyres in marginal conditions. Maybe not as good when it was really bad though/
    With the general winter tyre thing, I find that people that are 'against' them, have never had a set. While people that have had winter tyres are massive converts. It seems to pass people by, that when its 5 deg C and wet, you get much more grip with a winter tyre. Somehow they just associate them with snow, which granted isnt really an issue in much of the uk. Plus if you keep a car for long enough to go through a few sets of tyres the only extra cost is more tyre-swapping.
  32. beanoir
    2,171
    31
    So I think we've all ascertained now that you've never had winter tyres, your opinion is not based on experience and instead on your mates Peugeot 106 with underinflated tyres...
    Lets move on shall we :)
  33. liquids3
    liquids3 Member
    930
    22
    Yes think everyone's missundersanding the point!,just cant see the point in spending the earth for that week or two,if you want an all round wet weather and warm weather tyre that you can use all year round (bridgestone all season tyre is more cost effective!
  34. Alex C
    3,306
    375
    Is £700 worth it. Well for one £400 + £200 is £600 and you only buy the rims once, and thats if you havent already got a set of spare rims sitting at home. So lets say 4 winter tyres is £400. You are right you dont use them all year, so you only have them on say 4 months? Question for other people now, how quickly do they wear in winter conditions? Say you get 2 years of use (i.e. 8 winter months) out of them. So £200 quid a year. In winter you are 6 times more likely to crash. Cost of a crash anyone? Or cost of being stuck in the middle of nowhere in the cold? Cost of not being able to get to work? From what i have seen on the news the past two winters it has looked pretty expensive. Anyway thats my opinion(!)
  35. liquids3
    liquids3 Member
    930
    22
    I respect your opinion,and if you have a spare set of wheels to put on thats fair enough!,and i understand obveously you ar'nt wearing your summer tyres so would'nt work out that expensive!,thats fair comment!,my situations different (my opinion)!,not wanting an argument,id have to buy wheels tyres persanlynot for me!
  36. S3quatt
    652
    60
    From the above posts its obvious that liquid has never driven on winter treads... I got them after driving in Norway (Where it's the law) one winter & the difference really is chalk & cheese so I adopted it from there.
    & only a few weeks of the year??? Up in sunny Scotland here we had months of it last year!
    You just need to look at the news & see M-ways at a standstill to see the reason they should be made law over here too! The winters are only going to get colder...
  37. liquids3
    liquids3 Member
    930
    22
    No i hav'nt beacause ive neaver had a problem in the snow!,and its a few weeks down hear!,i expect you would want them
    in scotland!
  38. knoxie
    knoxie K4OXE
    619
    15
    wow got a right old debate going haha
    im after just a decent tyre that will fare up well against the wet/winter time, as when i bought the car it came with really bad budgets and they are pants if it pisses down, and im not even going fast :(
    i only ask as i use it as a daily driver, i dont really want to be spending a wad for them to wear out quickly
    knoxie
  39. beanoir
    2,171
    31
    So you don't actually want winter tyres at all then...?
    It now sounds like you want summer tyres that perform well in the wet also. Totally different kettle of fish in that case.
  40. Jason.s
    2,879
    348
    Uniroyal Rainsport 2's then for a cheap well performing tyre thats good in dry and wet.
