butler2.8i
This is winter protection on a Ford Focus ST
Products and equipment used
Uber microfiber towels
Uber drying towel
Valet pro bilberry wheel cleaner
Valet pro tyre gel
Valet pro orange pre wash
Valet pro PH neutral snowfoam
Valet pro citrus bling
Valet pro Talos Protectant
Meguiars hyper wash
Autosmart Tardis
Bilt hamber soft clay bar
Various wheel brushes
Karcher pressure washer
Noodle wash mitt
Lambs wool wash mitt
Poorboys microfibre clothes
Snow foam gun
Chemical Guys Jetseal 109
Collinite 476 wax
Autosmart Tardis
Ironx
Rainx
Autosol metal polish
00 grade wirewool
The car before I start
I cleaned the wheels using the bilberry wheel cleaner and various wheel brushes and a noodle wash mitt, the bilberry got the worst of the muck off just leaving some iron build up to be removed by the Ironx.
I started by giving the lower parts of the car a coat of the valet pro orange pre wash, which was left to dwell before being pressure washed off. The car was then given its first coat of snow foam made up of the valet pro PH neutral snowfoam and a shot of Megâs hyper wash The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and whilst this was still on the car I washed it using Megâs hyper wash and the 2 bucket method and a lambswool wash mitt.
The car was then rinsed off using a open ended hose and before claying the lower parts of the car and inner arch lips where sprayed with Tardis which was left to do its stuff before being wiped down with a microfibre cloth.
The car was clayed using citrus bling and water mix( 10 to 1) and a Bilt hamber soft clay bar which didnât really pull much from the paint work it was then rewashed using the same method and dried using a Uber microfiber drying towel.
The car was given 2 coats of Jetseal 109 leaving about 30 min between each coat these where applied using a german applicator pad and left to cure before buffing using poorboys microfibre clothes. The car was then given 2 coats of the 476 wax which were also given 30mins between coats and buffed using Uber buffing towels
Whilst waiting between coats all the exterior plastics and under arches were given a coat of Talos protectant and chrome badges polished using Werkstat Prime Acrylic. All the glass was cleaned using Rainx and alloys sealed using 2 coats of Jetseal 109, tyres dressed with valet pro tyre dressing.
Exhausts where cleaned up using Autosol metal polish and 00 grade wire wool
Uber drying towel
Valet pro tyre gel
Meguiars hyper wash
Autosmart Tardis
Noodle wash mitt
Snow foam gun
Collinite 476 wax
Autosmart Tardis
Ironx
Rainx
00 grade wirewool
