WING MIRROR GLASS REPLACEMENT
marktdisport Dec 27, 2011
  1. marktdisport
    marktdisport Active Member
    1,195
    15
    Anyone ever replaced a glass as my drivers side heated element isnt as good as the nearside, so ive ordered a new oem replacement just wondered if anybody as a diagram or and ideas were to start as i take it there very fiddly, thanks
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Door mirror Glass replacement. Tilt the mirror/glass and start pulling from the lower corner then tilt it down and do the same working around the glass be gentle.
  3. floatylite99
    floatylite99 New Member
    I've in fact just finished replacing the glass on my A4. I struggled removing the glass by pulling it out. Instead I removed the black plastic bottom part of the mirror (its only held in with two screws), you the have access to the back of the glass and it easy to just push it out then.
  4. quattrojames
    14,050
    575
    Good luck getting those two little screws out in the majority of cars!
  5. vr6gordy
    vr6gordy Well-Known Member
    2,775
    181
    why didnt you use 2 cable ties and place round mirror then give a pull ..comes off so easy this way
  6. marktdisport
    1,195
    15
    thanks for the info guys will be doing this the weekend if it arrives before then many thanks
  7. hades-
    9,481
    646
    as above 2 cable ties never broke 1 that way
