Windscreen washers
A4_MO Dec 15, 2012
  1. A4_MO
    A4_MO Member
    39
    Looking to change my washer jets to the fan jet style.
    Has any one done this if so which car did you get them off of
  2. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    156
    43
    They come from a passat mate. Gonna do mine soon. Remember there's heated and non-heated ones. There's plenty of guys done it on here
  3. chrisa4quat
    chrisa4quat Active Member
    970
    29
    It's a 7m0 or a 5mo part number iirc. Do a search you'll find loads on it. Have done this to mine. Still need to sort them properly as they don't fit in original cut outs too small. Mine are taped haha.
  4. A4_MO
    A4_MO Member
    39
    Will the ones off the MK5 fit do you know? Also are mine heated or is it the case of taking them out and seeing your myself?
    My car is a 2007 special s-line
  5. rizzini7
    983
    156
    43
    You should be able to see a cable if they're heated. They're quite easy to get out
  6. A4_MO
    A4_MO Member
    39
    Just seen how the new set will fit. Dont know if i like the fact that they have to be glued in because there to small.
