Windscreen washer pump.
norad97 May 13, 2013
  1. norad97
    norad97 Member
    126
    Hi,
    The windscreen washers have stopped working, jets are not blocked and i blew down the tube from the bonnet and the
    the bottle bubbled.
    There is no sound from the motor, I looked at the fuse layout and it seems its the same fuse as the wipes and delay,
    so I guess it cannot be that.
    What about relays? is it the same relay for the wipers, just want to check before I take things apart,
    dont want to remove the wheel arch lining for nothing and find out its electrical.
    The bottle is not easy to get at from inside the engine bay, I think I can take the pump of the bottle but not sure
    how much wire is on the plug so I can dissconect it and test for Volts.
  2. norad97
    norad97 Member
    126
    what' no replies at all, surely someone could help?
  3. aragorn
    17,956
    701
    pumps are cheap, throw a new one in and see what happens!
  4. norad97
    norad97 Member
    126
    Well, they are not cheap, My car has LCD display in the dash that show when water in bottle is low, these pumps are not £20.
    I took out the bottle today, removed pump and tested wiring for volts, found volts O.k., so off to GSF for the new pump, but when they
    showed me it' it was wrong and only 2 pins, I had my old pump with me and they could not mach it,the pump they sell it for standard car
    with no display info in dash. called TPS no stock, called the Stealers, no stock but £73.00 +vat !!!!!! so I took my pump apart a
    and found the motor seased up.
    sprayed with WD40 and bit started spinning freely, cleaned it up, put back in car and it works, water at last!!
    I realise this is only a temporary fix, need find a replacement soon.
  5. aragorn
    17,956
    701
    Yeh i just fitted a non-sensor one to my old car when that happened, lost the low level warning but at least it worked!
    Newer models have a seperate sensor and pump.
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Check breakers yards or ebay and see what's out there.
    I would not want to lose my low washer warning.
  7. Iceash
    Iceash Member
    391
    10
    Could the bottle be upgraded to take the new sensor on its own version?
  8. aragorn
    17,956
    701
    no, sensor works differently on the new version!
  9. Iceash
    Iceash Member
    391
    10
    Not even modding the loom?
  10. Bradderz_1988
    3,920
    231
    Is it only facelifts that come with the seperate sensor ??
  11. aragorn
    17,956
    701
    They changed over in ~1998, same time as they changed the clocks as depicted here:
    http://img217.imageshack.us/img217/9001/allclustersrev.jpg
    The earlier cars had a different washer and coolant sensor, which opened the circuit when everything was good, and closed it when washer fluid/coolant was low.
    I guess they changed it because "full" and "unplugged/broken" would then give the same "OK" signal.
    On the newer cars, the circuit is open when its empty, and closed when its full, which means they're not compatible, and also means "unplugged" flags an error, which is obviously useful.
  12. ScottD3
    15,161
    1,121
    Thich is the issue I got at the moment with my coolant bottle.
    I can't plug my coolant level sensor in cause it beeps.
    I assume I can use it when I fit my new clocks?
  13. Mr K
    Mr K Member
    335
    On a FL avant, is it one pump that does the front and rear? I noticed that one of the non-return valves was leaking so was going to replace the pump.
  14. norad97
    norad97 Member
    126
    hi Aragon when u fitted standard pump with two pins, did the three pin connector fit?? what about the low water display
    on the dash, is off or on all the time,
    and what did you block the hole in the bottle with as it would be open??
