Windscreen 'washer' jets - are your's rubbish too?
southpaw66 Jan 24, 2007
  1. southpaw66
    southpaw66 Member
    166
    Is it me or are the washer jets useless on the A3. Very noticeable this morning that the coverage is rubbish and there's a bit in the middle-bottom of the screen and half the passenger side that just doesn't seem to clean properly. How come Leon's and Golf's get those diffuse sprays and the A3 gets the old fashioned two jets?
  2. jamiekip
    jamiekip Guest
    Good question.... is the diffuser spray something that can be retrofitted from VW parts???
  3. cliveywolves
    cliveywolves Member
    229
    I was thinking how good they actually were this morning, seeing it was freezing cold and spray coming off the road all the journey, kept the screen really clean... I got a 2007 A3 sportback model......
    My previous in my BMW were a waste of time would not even work in the cold ...
  4. jamiekip
    jamiekip Guest
    Is that the wipers are good?
    Or the washer jets???
  5. cliveywolves
    cliveywolves Member
    229
    Both... jets worked after about 2mins after engine was on and wipes are excellent best i ever had on a car...
  6. jamiekip
    jamiekip Guest
    Maybe a good sign - specced may car with heated washer jets.
  7. southpaw66
    southpaw66 Member
    166
    Maybe it's the adjustment on mine. The wipers are fine when the whole screen is wet, but I don't seem to be able to easily wet the whole screen without holding the spray for a few seconds. I'm used to giving just a 1 second blast of water in my old shape leon.
  8. hburnett
    hburnett Member
    45
    Mine are good.... Altho the wipers need replacing every service so far!
  9. steve184
    steve184 Active Member
    1,138
    i agree my folks have an altea and the washer jets on that are superb they way the spray wide over the windscreen with a nice even spray - supposedly cheaper car with better technology than the 'premium' one - how hard would it be for audi to just fit these jets - cos them about 2 quid per car probably!
    I would also be interested to see if the jets can be changed from audi ones to SEAT ones
  10. jamiekip
    jamiekip Guest
    Or VW - my Mum's MKv golf has them!
    Anyone know if this is an easy mod???
  11. southpaw66
    southpaw66 Member
    166
    Is there a heated option on VW/Seat? Assuming it's this nozzle bit that has the heating elements.
  12. Amchlolor
    Amchlolor Active Member
    5,604
    Aren't heated nozzles standard ???
    I'm sure my car has them,but I didn't spec them.
    Visible steam when they're used on cold mornings and,for the first time ever in any car I've owned,they have never,ever,frozen.
    PS,I don't know how anyone can say the wipers are great,coz the passenger side is hardly ever cleaned properly.
    Always takes a few goes to get passenger side clean,even though driver's side will have cleaned first time.
  13. jamiekip
    jamiekip Guest
    Not sure if it's standard, I know when I specced folding mirrors it also said I got heated washer jets, so assumed tehy we're an option.
  14. southpaw66
    southpaw66 Member
    166
    Exactly.
  15. d3fy
    d3fy Active Member
    1,412
    Speaking of wipers, mine are really noisey some times and squeek on the return if that makes sense. They arch up, then return at that point there is a nasty squeek type noise. Anyone else? Have my blades had it, do I need new. They don't smear.
  16. cdb2
    cdb2 Member
    711
    Mine were squeeking like this , I cleaned the windscreen and they don't do it anymore.
  17. d3fy
    d3fy Active Member
    1,412
    I clean the windscreen and the wipers every week
  18. AL_B
    AL_B Well-Known Member
    1,664
    80
    This has pee'd me off for a long time. My 8L S3 ('02 plate) has the traditional washer jets and over time (4.5yrs) they get steadily worse. Yet our Golf Gti Anni ('52 plate) has the fan-spray washer jets!
    TT's (MK1's) have fan style jets too. I did start to have a look on the parts database to see if the fan ones could be retro-fitted. But I never got round to following it up with VAG-parts or somewhere.
    All that said, you can imagine how even more pissed off I was when I was testing driving the new S3 only to find out the "boffins" (NOT!) at Audi have decided to fit the f'in normal jets to a brand new car!!
    The fan style jets cover the screen so much better. On my 8L S3 almost every month I have to re-align the jet nozzles to try and get decent coverage. Its a pain in the arse.
    AL
  19. Vertigo1
    Vertigo1 Well-Known Member
    3,383
    542
    They're standard on all A3s. Where did it say about heated washer jets?
  20. Tooks
    Tooks Active Member
    753
    29
    You probably won't be surprised to learn that your local Audi dealer has a template they put on your windscreen for aligning the washer jets properly!!
    I wonder how many hours of research went into that?!
  21. southpaw66
    southpaw66 Member
    166
    Even better! They are this bad on purpose!
  22. treblesykes
    treblesykes Member
    690
    i found the fan jets on golf mk4's to be a pain in the arse, even on max adjustment they only reached halfway up screen, was glad to find normal jets on the audi
  23. stan
    stan Member
    136
  24. steve184
    1,138
    template hey? well someone please go tell lancaster audi manchester how to use it cos they clerly dont have a clue. car went in with jets fine, had wiper problems so they had to remove all scuttle panel (which washer jets clip into). when refitted they didnt clip the ets in properly so must have found the jets were hitting windscreen too low (hmm never wondered why they weren't like this before did they- ooo noooo they just went ahead and readjusted them!) i got car back notcied the jets werent clipped in - clipped them in as they should hae been and the final result was well it was the car behind me that got their windscreen cleaned not mine!!!!!! absolute mongs!
  25. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    My wipers squeek and its bloody annoying!!!
    I have used rainX on my windscreen and above 40mph wipers aren't needed as the water just runs off!
    Audi price and spec guide doesn't mention anything about heated washers as standard or as an option.
  26. jamiekip
    jamiekip Guest
    Hey Vertigo,
    When I was speccing my car up I selected folding mirrors:
    Here's the brochure:
    http://www.audi.co.uk/etc/medialib/cms4imp/audi2/uk/Products/a3/pdf.Par.0010.File.pdf
    Page 39 it reads:
    Door mirrors - electically folding, including heated washer jets
    It doesn't state they are standard fit in the brochure, unless it has changed for 07 cars....? I know they sometimes juggle the spec's - bit of an off one, as imagine there is very little in the cost with or without heating.
  27. RobinA3
    1,826
    46
    Ah you might be wrong there, when i had my Polo it came with heated washers as it was the 16V version, the rest of the range didn't have them as standard.
    When i had to replace one of them as one became faulty and didn't work, VW wanted £40 for ONE heated jet washer and then it was £6 for a standard non heated one, you can guess which one i went for in the end!
  28. jamiekip
    jamiekip Guest
    Sheeeesh, they have awsome mark-up on VAG parts hey!!!
  29. HeliChris
    HeliChris Learning to fly 3D
    195
    Just had a quick look on audi.co.uk
    A3 Sportback -> Price and Specification -> A3 Special Edition 1.6 102PS 5 speed
    Under Standard Equipment -> Exterior it lists
    Heated front washer nozzles
    Hope this helps
    Chris...
  30. jamiekip
    jamiekip Guest
    You're right Chris - wish they would make all there info consistent... price list deffo doesn't list it as standard, but web site specs does!
  31. cliveywolves
    cliveywolves Member
    229
    hi , my 2007 a3 sportback has def got heated washer jets as standard ... i used them this morning when the car was still frozen , after few mins of engine being on they were fine...
  32. marriedblonde
    marriedblonde Active Member
    4,371
    Don't have any problems with the wipers or jets on mine. Both seem to work fine and I'm still on my original wiper blades after 2 years.
    J.
  33. h5djr
    9,372
    1,723
    Heated washer jets have always been standard on UK A3s. Even my fist A3 1.8T Sport back in 1998 had them. It has always been a source of amusement with dealers etc than the were mentioned in the options together with folding mirrors. The two are in no way connected. Something got lost in the translation of the brochure to English I think.
    I must say that I have no complaints with either my wipers or the washers. They both work as the should and do their job OK. I do like the way the last wipe when you've used the washers is slower to help to remove any water left on the screen.
  34. Amchlolor
    5,604
    So you don't get great big chunks of the passenger side left dirty,when the driver's side is clean ?
    Funny,but every A3 I've driven does it.
    My A4 did too.
    I'll post photos of how it looks later.
  35. wilko
    wilko Top Gear
    725
    I prefer the old golfs washer jets they used to cover the whole screen with spray. I was expecting these on the A3 but.... would have been nice.
    Can't really complain tho the A3 wipers are great compared to the Vectra's (A hire car) I just had!
  36. h5djr
    9,372
    1,723
    Not enough to bother me. Only the area at the top of the screen where that the wipers done cover. Otherwise, generally it cleans the whole wiped area. Perhaps my washer jets are better adjusted.
