Windscreen replacement - anything to watch out for?
dope Jul 28, 2010
  1. dope
    dope alcoholic pervert
    199
    Need the front screen replacing after a stone smashed it today. The insurance uses Autoglass. Is there anything I need to watch out for or do I just trust them to do a good job?
    Are all the glass tints the exact same colour, and the blacked out bit at the top the same depth?
    I assume they'll have the wipers and plastic scuttle thing off which should come off easily since I put the new wiper mech on not long ago.
  2. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    Pretty straight forward job as you describe - had mine done ~4 weeks ago (3rd in 7 years) by Autoglass.
    If it was the winter I would be careful about the plastic scuttle below the wipers as this can be brittle when cold and the inter-locking strip can break off.
  3. dope
    199
    3 in seven years? unlucky fella!
    Odd how the cracks spread isn't it? There was like a 4 inch 'spiders web' immediately when the stone hit on the way to work. Now it's the whole height of the screen.
  4. Woorlord
    951
    17
    On the A4 here is quite a lot of body behind the black area's of the screen, and that is where I always seem to get a stone hit and here there is no give.
    Small 30mm cracks end up across the screen before too long.
  5. scott b
    scott b Active Member VCDS Map User
    1,254
    personaly would order a new scuttle panel, around £15 from audi, had to take mine of to do the wiper linkages, there a right twat to get of without breaking
