Hi,
Im hoping this may be a quick answer for someone that has the knowhow =)
Basically every now and again when the a/c is switched on the windscreen can steam up. Common sense seems to say there is moisture in the system somewhere, after doing a little research i believe it could be a part called the drier ? may need replacing as this collects moisture in the system ?? Hopefully someone may have come across the same problem ?? It isn't causing any probs as the a/c clears the windscreen in seconds after it steams up (lower 1/4 of screen) but i just trying to prevent anything in the future ..
If it is this drier, any ideas on replacing and how much£ ?
any help much appreciated
thanks
thanks
