Windows Vista Service Pack 2 is here!
MikeSel^ May 26, 2009
  1. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Gold Supporter Audi S3 quattro Manual
    1,146
    607
    Source
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Deployed it yet?
    Its been out for nearly a month
  3. Caesium
    4,879
    pah, its x86 only.
  4. Caesium
    4,879
    Got the x64 version which is no longer in Beta, ran it last night and left my PC to it, this morning I am now the proud owner of a system which is in full halt and will not boot at all.
    I am left with basically no choice but to system restore with Acronis to back in March.
    Poxy Microsoft twats
  5. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    FTW.
  6. MikeSel^
    1,146
    607
    Is it really that bad, post up the symptoms an see if we can fix it. If you havn't already rolled back to your restore point.
    We have just started testing it on our corporate network, but so far so good.. No issues like yours anyway!
  7. Caesium
    4,879
    Got it sorted now, the issue was Bitdefender saw some off the dll's as trojans and blocked them, when the machine restarted it stopped after about 5700 out of 74000 files being updated and just hung.
    I had to use the Vista DVD and do a system restore, then use msconfig to disable all non microsoft startup services.
    In device manager, disable the graphics card and sound card, and all external ports except the LAN port.
    Then reboot in safe mode, run the SP2 (with antivirus off obviously as its disabled)
    the machine then restarted with everything running as it should do.
    So beware your antivirus!!
    What a PITA
  8. Caesium
    4,879
    Yup I had that on a 386sx 20 with no math coprocessor, after that came 3.11 then WINDOWS FOR WORKGROUPS! woooooo!
  9. S3_Pricey
    S3_Pricey Member
    302
    I have Vista 64 bit OS with service pack 2, and have had no problems what so ever. In fact the only problem I have had with vista was when the computer was brand new and i could not install download programs, but that was solved very quickly. Vista has had a lot of bad press, and while I do not doubt that it has had many problems for alot of people, it has worked like a dream on my machine...
  10. Broken Byzan
    13,237
    465
    Yeah, to my downfall, i found out you have to have a working legacy DVD rom drive to use rescue as my SATA one only works in windows, PITA. "Borrowed" a drive in the end so all good now.
    SP2 working OK here. Alcohol 120% not so much,lol
