Windows up/down on Key fob.. I have searched but no def answer??
OVRA3 Sep 7, 2012
  1. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I've got a 2005 Sportback does it have the windows up on the keyfob feature or is this something that needs to be enabled? Mine doesnt work is there a way of resetting it, Ive searched an found threads on how to enable it with VCDS but should it be on there already and just need a reset?
    Cheeeeeeeeeeeeeeeeeerrrrsssssss
  2. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Comfort setting may need to be enabled, you need to find someone nearby with VCDS to check and code for you if required.
    Paul
  3. OVRA3
    1,079
    80
    Does it not come enabled? Thanks for your response :)
  4. Gti Jazz Blue
    1,655
    Can't remember if it was enabled as default on my 2005 A3 or not now.
    Does the one touch open / close work OK using the window switch ?
    Thing is if it is enabled and doesn't work then you are still going to need someone to check it with VCDS anyway.
    Paul
  5. OVRA3
    1,079
    80
    Yeah the one touch is fine but the fob doesn't work I'll have to get it sorted next time it's in, the mrs always leaves the windows down does my head in!!
  6. Geoff_UK
    Geoff_UK Member
    71
    works on my bog standard sport - leave windows down - press and hold lock button on remote.
  7. OVRA3
    1,079
    80
    What a spanner it does work I just didn't push and hold the button the second time doh!!! Sorry for wasting everyone's time :-(
    Geoff_UK likes this.
  8. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    Is it not done thro the DIS......convenience opening of windows or that just on newer models.
  9. Brodster
    3,548
    886
    Well done.........:keule:
  10. s88 esn
    s88 esn New Member
    do'h hahaha
  11. OVRA3
    1,079
    80
    I promise to try better next time 😊
