windows steaming up
andyollie Jan 5, 2005
  1. andyollie
    andyollie Member
    114
    any ideas why my a4 is doing this, some people say that in the back seat they can feel a draft?
  2. AndyMac
    9,832
    45
    Do you have aircon/climate control?
    Windows will steam up if the system needs regassing
  3. The Slug
    The Slug Active Member
    1,869
    if geating a draft, could be slight water getting into car, causing condensation. Use AirCon regular, this will extract the moisture from the air.
  4. QuantumJohn
    QuantumJohn Member
    142
    I also had a problem with my A4 that seemed to steam up very easily and took ages to clear. The problem got a lot worse when I got in the car recently and stepped into a pubble.
    I learnt a valueable lesson. If you find water in the footwell taste it first before concluding it is the heater matrix!
    I found the problem to be the small foam gasket that sits between the lower half of the engine ECU box and the metal bulkhead. This gasket had deteriorated over time and had been allowing water to seep in and run down the wiring loom. This has been compounded by old leaves sitting around the box and holding water.
    I lifted out the ECU and pulled aside the box, cleaned out and dried the bulkhead area and refitted the gasket with some sealant. So far, so good and it hasn't leaked since. However, I guess I have taken out over 2 litres of water from under the carpet, and because the carpet is backed with foam it has acted like a huge sponge. The drivers seat is out, the carpet has been lifted up and it is on it's fourth day of drying out.
    I suggest that all other A4 owners keep an eye on this problem. Chances are mine had been leaking for a while but not enough water for me to feel it through the carpet.
    My advice would be to remove the trim by the drivers footwell and puch your fingers under the carpet to see if it is wet.
    Hope this helps,
    John
  5. IanL-S3
    IanL-S3 Member
    923
    [ QUOTE ]
    [/ QUOTE ]
    You A/S4 owners are certainly a breed apart! /ubbthreads/images/graemlins/smile.gif
  6. IanL-S3
    IanL-S3 Member
    923
    Two things in my S3 which 'cause' the windows to steam up are when i run it with the recycler on or with the Econ on (condenser off) on a rainy day.
    As soon as i run the condensor - sorted. As an aside - I really like the screen clear button /ubbthreads/images/graemlins/smile.gif , but why hasnt anybody bar Ford AFAIK used heated elements in front screens.
    But QuantumJohn has got me thinking too......maybe i should get my carpet shampooer thingy out to it to suck up any moisture that maybe in there.
    Hope you get it sorted.
  7. The Slug
    1,869
    Heated Screens, not just ford use them but LAND ROVER too!
    Bloody nightmare when u get sunglare on the screen at the right angle, lol.
  8. IanL-S3
    IanL-S3 Member
    923
    Ah that would explain that!! /ubbthreads/images/graemlins/smile.gif Ta
    Still its quite old technolody - at least 10 years. Surely they could have sorted that by now! Or am i an ever-optimistic-the-future-will-hold-better-things fool! /ubbthreads/images/graemlins/smile.gif
  9. andyollie
    andyollie Member
    114
    thanks for the help lads:)
  10. S4Driver
    S4Driver New Member
    22
    [ QUOTE ]
    Hope this helps,
    John
    [/ QUOTE ]
    Wot he said /ubbthreads/images/graemlins/wink.gif
    I had the same problem in my S4.Windows were steaming up terrible.Found out the problem was water in the footwells being soaked up by the carpet.Absolutely saturated.
    All the trim was removed, and the carpet taken out to dry out. The cause of the problem was the leaves and muck around the battery tray drain.(?) This filled up with water then run down the air vent next to it and into the car /ubbthreads/images/graemlins/crazy.gif
    Fine now.
  11. QuantumJohn
    QuantumJohn Member
    142
    Dean,
    How long did it take for your carpet to dry out?
    I am thinking I should have removed the passenger seat and centre consule and taken the whole carpet out. As only the drivers side was wet I just removed the drivers seat and propped the carpet up. Have been using a fan heater occasionally in the car. It's been like that for 10 days now and it still isn't quite totally dry!
    John
  12. ajmackie
    ajmackie Member
    922
    rent a dehumidifier unit and put one in ur car.
    we had a load and when the bath overflowed and soaked everything, it soon dried everything out.
    p.s. my windows sometimes steam up but i don't have wet carpets. i find when i put the aircon on, the water that is condensed (dried out) doesn't drain properly so that when you switch it off, the air passing through then becomes super saturated!
