Windows steaming up/condensation, etc.
CycleSi Dec 1, 2007
  1. CycleSi
    CycleSi Member
    I know that the weather has changed and it is wet & damp, but l'm finding the rear window and rear side windows 'seem' to be permanently steamed up. I always have the climate control on and the windows are all closed properly. Admittedly l don't have it hot inside the car as l don't feel the cold much (climate control is set to 'Auto' 20.5).
    Am l imagining l have a problem or do others have this problem at the moment - it's just that when l look at other cars parked next to mine their windows are clear.
    Maybe I need to let it get really warm inside and dry out, or drive around with the windows open for a while?
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    is the aircon on?
  3. CycleSi
    CycleSi Member
    As l say, the climate control is always on - surely that is the same as the air con???
  4. HTC
    HTC Active Member
    3,428
    9
    Check if any of your carpets or the boot is wet. A guy I know at work had this problem with his S3. Turned out to be a leaking rear washer hose causing the damp.
  5. simch
    simch Active Member
    2,028
    Make sure its not on recirculation, otherwise what moisture that is in the car stays in.
    Take the recirc off and it will mysteriously be fine!
  6. Rev-head
    Rev-head Active Member
    2,987
    Try and cut down on the dogging with the bird that might help and you can check the carpets to
  7. Randomjim
    Randomjim Active Member
    2,752
    That's what stopped mine steaming up :icon_thumright:
  8. Sam-K
    Sam-K Has a throbbing red german.
    487
    And don't get into your car wet. thats what solved this problem to me.
  9. jojo
    28,935
    3,587
    I'm thinking of 2 problems here, either your aircon part of the Climate control is knackered or needs a regas(I take it that the ice symbol is lit up right?), which is why it's not clearing the screens of moisture. Or you have a water leak of some sort allowing water in and when the temps go up, it evaporates and goes onto your wondows as condesation, so check your pollen filter and see if it's sittng properly, it's under the scuttle panel on the passenger side.
  10. jojo
    28,935
    3,587
    How wet can you be? lol
  11. Sam-K
    487
    Well, Starts from being mildly damp.
    Towel drying is a good solution! or stand in the sun..:happy:
  12. AndyMac
    9,832
    46
    Yes either your condenser is knackered on the aircon or you've got a leak, probably from blocked drain holes under the windscreen wipers. Check under your carpets, they can appear dry to the touch but have 5 liters of water sloshing around underneath.
  13. concoursneil
    concoursneil Member
    328
    I agree with Jo, try changing your pollen filter, when i changed mine it does clear all windows much quicker
  14. CycleSi
    CycleSi Member
    Thanks for your replies.
    If l do indeed have a problem (as l'm not totally convinced anything is actually wrong bearing in mind the windscreen and door windows are fine) then l've narrowed it down to the following having checked everything else:
    1. Knackered condenser - how can l tell?
    2. Blocked drain holes under the windscreen wipers - how can l check these?
    FAO jojo - The other question l have is clarification on this "needs a regas, l take it the ice symbol is lit up?"
    What ice symbol? Where is it? Am l just being plain stupid here?
    Cheers everyone.....
  15. abdus
    1,827
    My question was whether the aircon was on: the climtae control might be set on 20 but with the aircon off. It's on the bottom left. If it doesn't show, then the aircon itself is not on. Just my thought.
  16. jojo
    28,935
    3,587
    I'm not sure which ClimateControl system you have, as you havn't stated the year of your car, but if it's anything like my one(T99), there should be an round ice symbol on the left hand side of the red display to tell you that your aircon(compressor) is on. This will flick on automatically when you hit the 'Auto' button on the CC unit anyways.
    Please also take note that the compressor will not work when the outside temps is less that 5DegreesC, no matter how many times you hit the Auto button, it will not show you the Ice symbol, it helps your compressor from freezing itself over, so doesn't damages it.
  17. jojo
    28,935
    3,587
    He's mentioned that he sets it to "'Auto' 20.5", which I presume means he sets it to 20.5 and hits the 'Auto' button, which would flick the aircon on automatically.
  18. CycleSi
    CycleSi Member
    Yes; that's how l normally have it.
    It's a 2002 225 bhp model so assume it has the 'later' climate control.
    Although l haven't checked yet, l can't actually remember there being an ice symbol. Will check in the morning whilst sitting in the traffic !
    P.S. Had a new pollen filter fitted at its annual service last month and the carpets don't seem wet.
  19. abdus
    1,827
    just a quick question though: what 'if' the 'auto' button doesn't flick the aircon on automatically?
  20. simch
    simch Active Member
    2,028
    take recirc off!!
  21. CycleSi
    CycleSi Member
    Recirc. has never been on. Neither is 'econ'.
    In other words l've checked all the numpty stuff.
    Are we saying that on 2002 later S3's there is no "ice symbol"?
  22. AndyMac
    9,832
    46
    It's a snowflake symbol and all Audi's have it.
  23. jojo
    28,935
    3,587
    Then it's either under 5degreesC outside, or your CC is fecked.
  24. CycleSi
    CycleSi Member
    There is a snowflake symbol on the dashboard when it is 5 degrees or colder.
    Can't see an ice symbol on the climate control display.
    Can anyone post up a photo showing the symbol please as l'm still not sure what some of you mean.
    Sorry to be dim but l'm getting contrasting replies.
  25. abdus
    1,827
    with:
    witthout:
  26. CycleSi
    CycleSi Member
    My climate control doesn't look like yours.
    My S3 is a 2002 which might be a 'later' model perhaps?
  27. abdus
    1,827
    but you can still see the symbol in yours. The 'ice/snowflake' symbol in the bottom left of the pictures I posted
  28. CycleSi
    CycleSi Member
    No, l cannot see the symbol and l'm positive it's never been there.
  29. jojo
    28,935
    3,587
    OK, we need closeup pice of a facelift CC panel with the ice symbol on, anyone?
  30. CycleSi
    CycleSi Member
    That is indeed what we need assuming there is an ice symbol on the facelift climate control?
    As l've said all along, l'm not certain there is even a problem but if there should be an ice/air con symbol then that could explain why the rear windows/rear screen are misting up (sometimes).
  31. rickquattro
    rickquattro Member
    589
    CycleSi, just following this. I had this problem too, the recirculation was off and "Auto" pressed on the CC unit. It used to trip out itself to Recirc also. The "Ice" thing from others comments shows in the DIS below 4/5 degrees of outside temp and had nothing to do with my problem.
    Whether on Auto or not the windows used to steam up. I ended up buying another compressor and now all is well. It was £303 + vat from Cheltenham Radiators. Brand new, not a refurm. This was £300 less than another supplier.
    The magnetic clutch on the compressor was knackered, so it didnt matter what buttons you pressed on the cc, the compressor pump never engaged or dried the air.
    HTH.
  32. CycleSi
    CycleSi Member
    Audi replaced the compressor under warranty in January so l assume it is still under warranty even though the warranty on the car ran out 2 weeks ago.
    How can l actually test it to see if it is all working properly? Should l take it to an air con specialist?
    l was hoping someone could actually confirm the confusion over the ice/snowflake symbol on the facelift climate control.
  33. abdus
    1,827
    confused.com
    does it look like that:
    [picture removed]
  34. abdus
    1,827
    or why not just post a picture of yours...LOL
  35. CycleSi
    CycleSi Member
    It's not that one.
    Sorry, l seem to be living in the 70's - haven't got a digital camera.
  36. simch
    simch Active Member
    2,028
    Isn't the snowflake symbol just the warning about it being close to freezing ie ice on road?
  37. CycleSi
    CycleSi Member
    That's what l thought too.
    Maybe that's why l can't see one on the actual climate control display?
  38. Felon
    Felon Slightly odd.
    87
    blimey this is getting complicated... The snowflake appears in the DIS display to show that the temperature is 5 degress or below. I also have a 2002 S3 and have never seen a snowflake anywhere - other than in the DIS. Anyway, the snowflake is a red herring...
  39. SimonP
    SimonP Member
    165
    There is no snowflake symbol in the climate control screen of a facelift S3.
    There might well have been in earlier versions.
    Facelift's started around X reg.
  40. SimonP
    SimonP Member
    165
    CycleSi - if your rear windows are steamed up but the windscreen itself is clearing fine then it sounds like your CC might be ok, but there might be some damp in the rear? If your windscreen is a pig to clear as well then maybe a closer look at the CC is required.
    Have you checked that the washer pipe isn't leaking, and also that your rear-wash wipe hasn't corroded at the centre pivot as I've read that's a problem with A3/S3's - that might be leaking moisture into the boot. Then there's the boot seal itself, if that's not water tight (dirt etc) then it might also let water in.
