Windows going down on their own
cruisinbeatz Feb 24, 2013
  1. cruisinbeatz
    cruisinbeatz Member
    71
    Hey all, new problem again, when I open the RCL on the car my windows roll down, normally you have to hold the button in but it's just an unlock. I've checked the ccm and its as dry as snuff nod all wire appear to be ok. Anyone got any clues?
  2. cruisinbeatz
    cruisinbeatz Member
    71
    Also noticed the doors keep unlocking or trying to unlock when your driving along. Anyone got any ideas?
  3. kite
    kite Member VCDS Map User
    677
    Scan for faults. ..
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    I was going to say remote problem but the remote shouldnt operate the doors when the car is running
  5. krisavant
    krisavant Active Member
    449
    61
    Sticky key lock?? Maybe..
    Even though you use the key remote to unlock the car, the manual key lock can get full of gunk and cause the issues your having.
    Obviously better to completely remove the lock and clean it out but if you can't get some wd40 in the lock using the key to free it up.
    Had this happen to me twice on vag cars.
  6. scottshere
    scottshere Member
    369
    17
    Wiring issue to the drivers door?
  7. Blackie
    Blackie Active Member
    697
    67
    Broken wire in the door hose
    Mine did it and sent the windows & locks haywire. It was the big brown one & i pulled the boot back enough to solder & piece of wire in & shrinkwrap it. After that it was all good
  8. cruisinbeatz
    cruisinbeatz Member
    71
    Thanks for the replys guys, I read the computer today and got a shopping list, so i cleared them and these kept popping up every time for the CCM or CCU as some call it.
    2 Faults Found:
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01031 - Central Locking Key Switch; Driver Side; Unlock
    27-00 - Implausible Signal
    Make any sence to any one?
  9. stu_m
    1,441
    going by that you have either a busted lock or a broken wire
    check the wiring first as its easy and free
  10. cruisinbeatz
    cruisinbeatz Member
    71
    Check in the black tubing going from the chassis to the door? or where else?
  11. stu_m
    1,441
    Yeah peel back the rubber boot and have a look its a bit fiddly also pull the connector block off there is a tab you push in on the opposite side I had broken wires and corroded pins and 2 pins had snapped off
    use a mirror and a torch to check the pins in the connector if you cant see anything on the wiring you may have to take the door card off and release the cable so you can pull it through more most of the time you can see it though
  12. cruisinbeatz
    cruisinbeatz Member
    71
    Peeled back the rubber and there's a plastic clip. At each side. Can only look at wires from chassis side of car as other side is wrapped with something. Tried to put all back but the rubber won't go back on and the clips won't either. Cant see any broken wires at chassis side. Don't know what do do next.
  13. cruisinbeatz
    cruisinbeatz Member
    71
    Little update guys, seems like you all were right, the wires were broken, took loom out eventually, not without breaking the clip that goes into the chassis but however. Repaired the cables, but will replace the cables next time completely instead of cutting the bad bit out and replacing as it will be much neater. Thanks for the heads up anyhow guys, will do a read in vag com next to see if that cured the problem there.
  14. cruisinbeatz
    cruisinbeatz Member
    71
    Further update guys, this didnt fix the problem, I only thought it did as it didnt do it that evening, it still does it. What next to check?
  15. krisavant
    449
    61
    I still say sticky key lock mechanism.
  16. cruisinbeatz
    cruisinbeatz Member
    71
    I have a feeling your right, when using the key only sometimes it locks and unlocks the car. Would that mean the full would need replaced?
  17. krisavant
    449
    61
    No need to replace anything.
    Just take the lock barrel out, give it a good clean with wd40, regrease then put back in.
  18. cruisinbeatz
    cruisinbeatz Member
    71
    That can be taken out with the 1 screw from the side yes?
