Window Washer Fluid Level
Superman23 Nov 24, 2013
  1. Superman23
    Superman23 New Member
    25
    Stupid question really but how do you know what level is in the window washer bottle and how much do you put into it to bring it back up?
  2. ivicker
    ivicker Member
    58
    25
    It's usually impossible to tell how much is in there either by electronics or by manually looking. It will warn you on the screen when it's running low (assuming it's the same as my current Q3)
  3. Battlekrapz
    Battlekrapz Active Member
    418
    241
    43
    I just fill it up everytime i wash my car.
  4. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,578
    1,175
    Yep, you get a warning when it runs low. You put enough it to fill it up again...
    Silky-S3 likes this.
  5. dieseldoug
    dieseldoug Member
    240
    53
    Yes you get a low level warning, I have just thought it my be on the cars fitted with xenon head lamps only. Someone please correct me if I am wrong
    Cemerson do you think it's only with the xenon lights?
  6. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,197
    1,833
    Doesn't state that it is fitted only with the HID's in the Saloon brochure...
  7. Daveotto
    Daveotto Moderator Staff Member Moderator Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,933
    4,270
    Filled mine up for the first time the other week and takes about 1 gallon (4.5 litres - or two 4 pint plastic milk bottle containers) to top it right up, and before anyone says I did not fill it up with milk
    It warns you with a symbol on the DIS and a beep which is bloody annoying and kicks in every 1 - 2 miles on the road and annoyed me so much I pulled off the road and topped the level up with the remains of a bottle of water I had in the car until I got home.
    P.S My 8P with standard Halogens also had the low level indicator in the DIS....but without the beep
  8. cemerson
    4,578
    1,175
    No, I think the warning is with all models. I hadn't thought about it before, but I guess it could be a legal requirement to have the warning when Xenons are fitted - it would make sense. Probably cheaper just to make the one way of doing it in the factory, the sensing equipment is probably cheap enough to include on everything - variations cost money at the end of the day!
    adityamatharu likes this.
  9. cemerson
    4,578
    1,175
    I've had the warning pop up a couple of times now, not noticed the repeated beeping though, but the symbol stays there until you do something about it.
  10. bleedsoff
    bleedsoff Active Member
    236
    129
    43
    Do you fill up with any standard screen wash. or use the VAG stuff? Been told to use VAG stuff due to the fact of the it contains oil for some sort of motor and that it will keep the VAG fan spray design working throughout the life of the car.
  11. cuke2u
    6,197
    1,833
    Ok, think about it, does spraying oil mixed with water onto your windscreen sound like a good idea?
  12. bleedsoff
    236
    129
    43
    Ok lubricant then :p
    Just had a quick google, loads of stuff on there about it! Some say it basically myth other say the opposite. So I guess it down to personal choice and what you believe in.
  13. Daveotto
    2,933
    4,270
    Screen wash will contain some sort of detergent and therefore will have surfactant properties and therefore have inherent lubrication properties.
    If VAG are saying use there own highly priced stuff to maintain the pump then the pump must be pretty cheap in the first place, which I doubt, so expect it is VAG BS to sell more highly price inflated screen wash.
    i suggest buying a screen wash for it's ability to clean the screen not lubricate the pump!!!
  14. cuke2u
    6,197
    1,833
    I can't see how the washer fluid would be allowed near the bearings anyway, even if it has 'lubricant'. I think the recommendation to use their own is more to do with the spray jets getting blocked...
  15. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    Yup.
    Their screen wash stops crud and crystals building up that blocks the washer jets.
    I think its got something in to to help protect chrome trim as well.
  16. RS5UK
    RS5UK Member
    But oil doesn't mix with water. The oil would just float on top in the reservoir unless you used an agent to make an emulsion. Then you're likely to get gunk building up in the system and clogging the jets.
  17. cuke2u
    6,197
    1,833
    Well of course, that's another reason that it is absurd...
  18. gneera
    gneera New Member
    10
    In Finland we have it (low level warning) as a standard even on the 20years old toyota corollas. Is this feature only on the cars in the nordic countries with the sleety muddy roads where u have to fill it up several times during the winter? And ofc we're always adding some antifreeze fluid mixed with the water, do you do this in the UK?
  19. ScottD3
    15,163
    1,123
    I'm not sure how other marques determine what trim level or model level has the washer fluid sensor fitted. My 20 year old Ford Sierra had this feature as did my BMW of the same age and both was not really high trim level. The Lander Rover and Toyota never had it and they was semi decent trim levels.
    In work at the moment we got a 12 plate basic level Golf and that does not have it or does the new transit.
    I guess its safe to say that a van won't really have this feature but part of me is shocked that not every car is fitted with it, its not as if its the height of technology any more.
    I most car guys/gals will add a mixture of water and screen cleaner which normally has a basic level of anti-freeze in it.
    I've always used the Audi stuff and mix 50%50. Apparently its good to -20 and it does a pretty good job at cleaning the screen.
  20. jimladallen
    jimladallen Active Member Q2 owners group
    105
    33
    Hi all,Have used Morrisons cheap stuff in my A1for 2 and a half years with no detriment.Also the A1has a warning as to low water level.
  21. cemerson
    4,578
    1,175
    I just use the carplan pre-mixed stuff that you buy in 5l bottles and just pour it straight in. Works well.
  22. bleedsoff
    236
    129
    43
    To be honest I like the VW stuff. Works well and is not the expensive, about £3 for a 1 ltr of concentrate. With pre mixed stuff aren't you paying for water mainly? I guess that could be good if you live in a hard water area.
  23. cemerson
    4,578
    1,175
    Yeh, but £2 for 5l pre mixed vs £5 for 1l concentrate? I'm not complaining.
  24. ScottD3
    15,163
    1,123
    Where was that from?
    I paid £3 for 5 litres concentrate from Audi.
    Bought 20 litres, mixed it 50%50 got 40 litres of -20 screen wash. :)
    Apparently its good for WMI cars as well due to its high levels of meth.
    gneera likes this.
  25. cemerson
    4,578
    1,175
    Dunno, just from the local petrol station!
