Window Regulator Wire has snapped :(
bigblokey0 Apr 16, 2010
  1. bigblokey0
    bigblokey0 Member
    745
    my Window Regulator Wire has snapped on the drivers side so now i cant open the window ive seen these items for sale on ebay for about £16 are they easy to fit and is that a good price ?
  2. Mister D
    Mister D New Member
    Not sure about the price, mine had snapped but I just replaced the full regulator, £55 delivered from Euro Car Parts.
    Changing the full regulator was pretty easy, not sure about changing the wire but should be simple enough I imagine
  3. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    I managed to pick the whole door inner from a scrap yard and took the wire and motor as one unit and just replaced that, but that was in my Audi Coupe. Try to see what you can get first, but £16 sounds good for a go yourself.
  4. bigblokey0
    bigblokey0 Member
    745
    so did you not have to fit the wire around the rollers ?
    ive tried fitting the new wire around the rollers but i must be doing something wrong as the wire doesnt fit right its either to long or to short ive tried searching the net for fitting instructions but to no avail :(
  5. Watty
    404
    It might be that the window glass has to be down (or up), as if the wire broke, the motor will be in either up postion, or fully down??
    Try taking the other door card off and look at that one for comparrision?
  6. bigblokey0
    bigblokey0 Member
    745
    you have to remove the motor anyway to fit the new wire ive tried the wire in both up and down position but still no luck :s
    i could look at the other door but it would mean i would have to remove the motor and everything else and risk messing that one all up aswell
  7. Mister D
    Mister D New Member
    The wire was already fitted to it, I fitted a brand new regulator
  8. bigblokey0
    bigblokey0 Member
    745
    so what exactly does the regulator consist of ?
  9. bigblokey0
    bigblokey0 Member
    745
    Forget that ive had a look on ebay
  10. Flatdog
    Flatdog New Member
    25
    I fitted an ebay regulator wire to my A6 yesterday, I fitted it with the window up. It was a bit fiddly and there was swearing involved but I found it easiest to loop the wire around everything except one of the bottom pulleys, then with a couple of thin screwdrivers managed to coax the wire round the last pulley. I should have taken pictures. hope it works for you.
  11. bigblokey0
    bigblokey0 Member
    745
    I gave up in the end and just fitted a new regulator
  12. vtraudt
    vtraudt New Member
    29
    When the wire is snapped or badly frayed, its in deed easier to find a cheap complete regulator and swap the unit out.
    But if the window is just slow going up, stopping, reversing, in most cases, only one of the 2 plastic clips are broken (front windows).
    They are fairly easy to replace (good DIY write ups available).
    I stock them. Orders placed before 12 noon EST ship same day.
    See here:
    RegulatorFix.com
    Note: I have NOT found any manufacturer for the REAR C5 A6 window clips (I do have the front and rear clips for the C6 A6 though).
  13. d3m0n
    d3m0n Member
    45
    my wire snapped inside the gear thing, so replaced the whole lot. was a pita drilling the old rivets out and putting the new ones in (you have to go to Audi for them btw) once you have all the bits its a 30 minute job.
