Window help
chris199 Mar 30, 2014
  1. chris199
    chris199 Member
    39
    Hi guys bit of a problem my drivers side window has gone down but I can't get it back up ? Any ides on how to manually get it back up without breaking anything I've orderd a new switch as it's the one I have at the moment that I think is faulty, just I can't use the car if the window is stuck down :( any help much appreciated
  2. Arnie013
    Arnie013 Member
    152
    13
    This could be broken wiring in the door loom mate. Common problem.
  3. chris199
    chris199 Member
    39
    Jeez I hope I'm hoping it is just the switch nice easy fix, fuses ok and relays are ok so next port of call is the switch I think fingers crossed, just need to get the window up then al be ok
  4. rizzini7
    rizzini7 Active Member VCDS Map User
    977
    153
    43
    You got window roll up on the key remote mate?
  5. hades-
    9,481
    646
    do the other wivdoes work ?
    does the locking and mirrors work ?
    if yes its not the loom
    as above press and hold lock for a few seconds it should roll the window up
    if it doesnt its the motor
  6. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    391
    Chris, when you say its gone down, did it go down silently and using the electric motor or did it get stuck a little and grind etc. When trying to get it back up does it make any noises etc?
    I only ask because there is a common problem on both Audi's and VW's regarding the window regulator mechanism. its a common fail and pretty reasonable to fix. I am sure there is a how too on here but it does mean stripping the door and fitting a new mechanism.
    I just wanted to get clarification, it may be an electrical fault as you 1st thought.
