Window fault diagnosis help, please!
mjsewell Jan 10, 2012
  1. mjsewell
    mjsewell Member
    74
    Drivers window has been playing silly buggers and randomly responding to the switch over that last few weeks. Today they've all decided they're no longer going to respond to switches in the drivers armrest.
    All the windows go up and down happily via the remote, so assume this means I can rule out any issue with the motors and regulators. The other three windows also respond to their own individual switches.
    So, I was kind of hoping this means it's just the switches in the drivers door.
    But, a mate came round earlier and did a quick VCDS scan and these are the results which are all connected with something called the central convenience module (which I guess is a lot more expensive than some switches). Does that sound possible/likely given what is still working?
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CH
    Component: Komfortgerát T3B 4035
    Coding: 06895
    Shop #: WSC 06325
    VCID: 79F2609463C2721
    Subsystem 1 - Part No: 8E2959802E
    Component: Tõrsteuer.FS BRM 0506
    Subsystem 2 - Part No: 8E2959801E
    Component: Tõrsteuer.BF BRM 0506
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    theres no fault code on that it only tells you if youve got a particular system!
    why didnt he read fault code??
    i would check the wiring in the rubber boot in door opening
  3. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Had this problem, changed the drivers main switch and has been fine since. Part was £40ish from Audi.
