Wind/road noise
tangerinedream Mar 26, 2012
  1. tangerinedream
    tangerinedream Member
    249
    Anyone got any tricks to reduce noise from either wind or road , mine seems to be getting louder but i cant feel any wind around seals??
  2. Bradderz_1988
    3,946
    235
    Mine s the same seams as though its coming from the left hand side of windscreen where the pollen filter is its got a rac windscreen in but cant see it being the sealing of it as there is no water ingress checked pollen filter and all seems correctly seated.
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    I got the same on my drivers side, right above my ear.
    really annoying.
    I'm going to adjust my door again and see what happens.
    If adjusting the main door don't help, I'll just adjust the window frame to push in a bit at the top.
  4. tangerinedream
    249
    Think mines been like it since rhe respray just to much adjustment on the doors and window frame lol need two people to hold door while adjust really annoying thou
  5. aragorn
    18,137
    765
    I think it'll be the window frame/door alignment. The rubber door seals also seem to lose their spring when they get old, so they sort of flatten down.
  6. ScottD3
    15,161
    1,121
    I wonder how much new ones are.
  7. wallace78
    wallace78 Member
    146
    get a set of wind defusers of ebay!!!
  8. ScottD3
    15,161
    1,121
    Still noisy.
    Mine is :(
  9. Foxmeister
    Foxmeister Fired Up!
    1,785
    Get the amps in Scott!!!:arco:
  10. tangerinedream
    249
    I think i may have foumd a pro lem with mine , i appear to be missing the rubber seals that push into the top channel on the door seal basically have door seal but not the bit above it , i tried to steal them from a breakers but couldnt remove without damaging :( im also struggling to find o,e part no on etka can anyone help??
  11. aragorn
    18,137
    765
    photo?
  12. tangerinedream
    249
    I will get one up tonight , hard to explain but if u open door i just have a metal channel rivited to top of door opening whereas you will have a rubber seal?
  13. ScottD3
    15,161
    1,121
    I'll get a pic of mine.
    tell me whats missing.
  14. ScottD3
    15,161
    1,121
  15. tangerinedream
    249
    First pic on body of car notthedoor itself its the top seal that runs the lenth of both doors goes behind b pillar
  16. ScottD3
    15,161
    1,121
    The black rain gutter looking strip?
  17. tangerinedream
    249
    Something like that yh lol got the channel riveted to body but im missing the actual black seal bit
  18. ScottD3
    15,161
    1,121
    Odd, I wonder where that went then.
    Can you buy it from audi?
  19. tangerinedream
    249
    It had to be taken off when respayed bloke obviosly put new gutter in but maybe disnt want to fork out for the seal who knows? Im struggling to find o.e number on etka so if any one can help?
  20. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Try rubbing some silicone grease into the seals, it rejuvenates the rubber and makes it more flexible - I've just done the wife's car as part of the 10,000 mile service. If you are really keen, see if you can get some 'icex' - this is excellent for keeping rubber supple, although I suspect it is VERY expensive as we use it at work :thumbsup:
  21. Mackers
    Mackers Member
    291
    just a quick question, how do you adjust the window frame (as my passenger door is ok) but the top corner of the door has a wind noise when driving.
  22. ScottD3
    15,161
    1,121
    Not a bad idea.
    Not thought about treating the rubber.
    Worth looking in to I think.
    Take the door card off and there is 4 torx bolts, 2 on each side that adjusts the window frame.
  23. tangerinedream
    249
    Can you adjust the window frame i thought they had fixed holes when i was putting my car back togeter but may be wrong?
  24. ScottD3
    15,161
    1,121
    There is a couple of mm of movement.
  25. tangerinedream
    249
    Im still struglung to find the audi no on etos anyone help
  26. aragorn
    18,137
    765
    Illustration 853-10 is the best i can find, no idea which part it is though. could be 24, 25 or 26.
  27. ScottD3
    15,161
    1,121
    which part you looking for?
  28. tangerinedream
    249
    Thanks aragon bit this is the dilema lol i think its 24 but ill habe to pop into a dealer see if they have more details
