Will TT pedals fit an S3
Parf7 Oct 10, 2003
  1. Parf7
    Parf7 Member
    31
    Will the alloy pedals off a TT fit an S3?
  2. MickHumphrey
    MickHumphrey Member Team Sepang Audi S3 Black Edition
    51
    In a word Yes!
    About £18 for all 3 including VAT from your local Audi dealer..
  3. MOSSY
    MOSSY Member
    93
    I thought these pedals were alloy? If they are then there is no way you can stretch alloy, or am I missing somthing here?
  4. RAPS3
    RAPS3 Well-Known Member
    1,142
    135
    Mossy,
    They are a rubber pedal with an alloy coverplate sitting over the top, with the rubber protruding through the holes. If you get my drift. The rubber needs to be stretched over the actual foot pedal.
  5. s8n
    s8n Member
    207
    bb s3, im in Sydney and have the TT pedals, just ring up Spare Parts Audi and ask for the 3 Pedals.. Will cost you about $90aud all up
    The dead pedal has to be ordered and modified to fit, so I didnt bother
  6. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    ......any other opinions on the LHD or RHD accelerator pedal choice, as I am thinking of doing this mod to my S3?
  7. Parf7
    Parf7 Member
    31
    I have just fitted a complete set, all RHD. No problems what so ever. The fit was perfect
  8. JayBeeS3
    JayBeeS3 Member
    114
    fitted a LHD set of pedals a week ago.
    fits and looks perfect!!!
    Thinking about the footrest because the dealer couldnt find the part # (??) /ubbthreads/images/graemlins/beerchug.gif
  9. ooooaudi
    ooooaudi Member
    168
    just fitted a full set on my a3 with foot rest, with the left hand acc pedal - got the parts from v.a.g parts..
  10. JayBeeS3
    JayBeeS3 Member
    114
    [ QUOTE ]
    Gambba said:
    8N1 864 777A
    See....
    [/ QUOTE ]
    thanks again dude! /ubbthreads/images/graemlins/smirk.gif
  11. Gambba
    Gambba Active Member
    1,361
    [ QUOTE ]
    S3 Mike said:
    oh yeah........is it worth getting them from Audi, who are charging £7.14 per pedal?
    [/ QUOTE ]
    Mike,
    If you take a look above the accelerator pedals only a few quid and it's only the brake and clutch that are 7 or 8 pounds. I've seen the sets available through sites at well over 20 quid and would say that Audi is probably the cheapest in this case.
  12. MarkS3
    MarkS3 Member
    Gambba will the footrest (part number shown) fit my LHD S3, thanks
  13. Drill
    Drill Member
    928
    Mark, if you want confirmation.... I'm putting one on my A3 this weekend /ubbthreads/images/graemlins/grin.gif
  14. Gambba
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Yes Mark, the part number is for LHD vehicles only. If you save the pic that I posted you can zoom in and see the top numbers are for LHD with the various colour options underneath.
  15. Drill
    Drill Member
    928
    Well, the footrest seems to fit just fine on a LHD A3 /ubbthreads/images/graemlins/grin.gif
    Well, "Linking" doesn't work cause you can't say Tiresmoke on ASN /ubbthreads/images/graemlins/crazy.gif
    SO here:
  16. Drill
    Drill Member
    928
    And here:
  17. JayBeeS3
    JayBeeS3 Member
    114
    hey Drill,
    is that the denim blau version?
    so only the strip on the left side is blue?
    looks verrrry good. much better then the plastic standard footrest.
  18. MarkS3
    MarkS3 Member
    thanks Drill, i will order mine tomorrow
  19. Drill
    Drill Member
    928
    Thx fellas /ubbthreads/images/graemlins/beerchug.gif
    Jereon, yup, it's the Blau one /ubbthreads/images/graemlins/smirk.gif
    As for fitting, it was pretty simple, undid the phillips screw, pushed the old one up, and pulled it out. Lined the new one up, slid it down (while pounding a bit on it /ubbthreads/images/graemlins/crazy.gif) when the screw hole lined up, I put the screw in, and viola! Done /ubbthreads/images/graemlins/beerchug.gif
  20. Leddy
    Leddy Member
    213
    I received my TT pedals from VAG Parts on Saturday. Fitted the brake and clutch pedals fine but the TT accelerator pedal is quite a bit wider at the back than my standard pedal, therefore won't fit!!! /ubbthreads/images/graemlins/frown.gif
    Any Ideas? btw i have a late 2001 model RHD A3 1.8TS and I ordered the LHD pedal.
  21. acf8181
    acf8181 Member
    97
    [ QUOTE ]
    [/ QUOTE ]
    i recieved mine on saturday from vag parts as well!!! fitted to my golf no probs...bit fidly mind and the acc pedal had to be bent staright a bit (easy to do with hands).
    you sure its a lhd acc pedal, mine is 44mm wide exactly and its definatly lhd.
  22. Leddy
    Leddy Member
    213
    yes my TT pedal is 44mm also, however my stock pedal is only 34mm!!! did they change the acc. pedal on later A3's?
  23. Drill
    Drill Member
    928
    Dude, did you soak the Acc. pedal in some hot water before trying to slide it over your A3 one?? My A3 is a 2001 and I got it to fit (although I've a LHD)
  24. Leddy
    Leddy Member
    213
    No the new (TT) pedal is too big!!! i did soak the brake and clutchpedal however and this made them easier to fit, but i doubt this method will shrink my new pedal!!!
  25. chuffer
    chuffer Member
    72
    I had to glue the acc pedel over my old cover it was alittle Blue Peter ish but it to worked.
    James
  26. Leddy
    Leddy Member
    213
    i must admit to considering this but it would be prouder than the others, can't be right as other guys here are happily exchanging them??? /ubbthreads/images/graemlins/crazy.gif
  27. acf8181
    acf8181 Member
    97
    [ QUOTE ]
    [/ QUOTE ]
    from the sound of it you need a RHD accelarater pedal...phone the supplier and see if they'll exchange it (but get them to measure a RHD one first!).
  28. Drill
    Drill Member
    928
    [ QUOTE ]
    [/ QUOTE ]
    Sorry dude, wasn't paying attention /ubbthreads/images/graemlins/crazy.gif I had no idea that the pedals would be so much smaller on RHD /ubbthreads/images/graemlins/confused.gif
  29. Ess_Three
    Ess_Three Active Member
    5,383
    14
    I can't understand what all the fuss is about...
    RHD car...RHD TT pedals.
    LHD car is different.
    I've had my TT pedals in for as long as I can remember...and they are a straightforward swap.
    Basically, TT, S3, Lupo, Mk4 Golf all are directly interchangable.
    Mk3 Golf needs the accelerator pedal straightening to fit a TT/Mk4 Anniversary pedal set - all the rest go straight on.
    Last generation Polo (6N / 6N2) require a LHD accelerator pedal when fitting pedal covers.
    ..and another thing!
    Why does everyone - including VAG - refer to them as alloy pedals?
    Anyone who has had a close look / feel will know they are not aluminium or any of it's alloys...they are stainless steel.
  30. jimboA3
    jimboA3 Member
    336
    I'm trying to fita set to a 99 A3TQ , so annoying , they just wont go on , are there different versions for different years ? Will they actually fit anA3 ? Please someone help before i scream and snap them ! lol !
  31. Drill
    Drill Member
    928
    Alright dude, first of all, mine pissed me off too /ubbthreads/images/graemlins/grin.gif
    Where are you having the problem? Brake, gas? And have you tried soaking them in the hot water first?
  32. PaulRS3
    PaulRS3 Well-Known Member
    1,209
    141
    pop existing covers off.
    clip new ones on.
    Brake pedal is a pig to say the least as it has a hole in the middle which a bung on the back of the new pedal has to pass through to secure.
    I did mine with no hot water assistance or any form of tools. just persist.
  33. danh
    danh New Member
    Did mine last weekend. Clutch was the hardest, one of the corners didn't want to go on. Keep wiggling, it will eventually. Hot (and then very hot) water definately helped.
    I got the RHD acc cover for my 02 S3 and it fitted no problem - the easiest of the 3.
  34. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    i've got an A3 1.6, so will the TT pedal covers and the foot rest fit mine?
  35. Drill
    Drill Member
    928
    LHD or RHD?? /ubbthreads/images/graemlins/confused.gif
    Any chance of a pic?
  36. darkspin
    darkspin Member
    45
    [ QUOTE ]
    [/ QUOTE ]
    so are the existing pedals not secured down with a screw from underneath or anything? I did try forcing the brake pedal but it seemed to be stuck down by something at the top so i didnt bother force it. As for the other pedals i found them even harder to take off so right now im a bit frustrated by it.
    I will try this hot water treatment
  37. dickys3
    2,954
    You need to force them off. they are only held on by Rubber! Mine were stuck on and I used Mole grips to get them off. I actually destroyed them getting them off!
    With the new pedal covers, soak them in warm water and it will be much easier to fit.
  38. darkspin
    darkspin Member
    45
    i managed to get em off yesterday but boy did my fingers ache after lol
    the hardest one to get off was the accelerator so i decided to use a screwdriver to yank the plastic bit up and eventually i got it off
    the only problem i had in putting the new ones on was for the clutch due to it having to be wrapped around allover - not sure why they didnt make it in the same way as the brake cover. Anyway just got to get the footrest now /ubbthreads/images/graemlins/grin.gif
  39. larsmate
    larsmate Member
    121
    Leddy, I have the same problem - TT accelerator pedal too big ie rubber backing 10mm wider so may have to glue it on.
  40. Woodster
    Woodster Welcome to my world...
    84
    Just did mine at the weekend, only had a problem with getting the accelerator pedal off. Just used brute strength and ignorance /ubbthreads/images/graemlins/wink.gif
