Will these work with my car?
OVRA3 Oct 25, 2012
  1. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
  2. JS3
    JS3 Member VCDS Map User
    227
    Worth a go? They offer a full refund incl postage if they do not work.
  3. hades-
    9,481
    646
    didnt work on my old a4
    took about 6 weeks to get refund had to go through paypal
    if you do need to send them back make sure you record them back
  4. OVRA3
    1,079
    80
    Hmmm I read somewhere that there are units from Audi with the LED's for the new cars does anyone know if this is true and has a part number?
  5. big harty
    big harty Member
    307
    15
    No they don't work. Bought them for my2007 s3. They kept flickering then one went out and through up error on dash. Don't bother matey
  6. OVRA3
    1,079
    80
    Thanks buddy, have you managed to find any that do?
  7. big harty
    big harty Member
    307
    15
    None yet tried three different sets now. I'm back to boring standard ones
  8. JS3
    227
    I believe there are - ask t8ups he will be able to tell you. Think the unit is around £15 for each side from Audi (i.e. £30 for the pair) and then they need to be coded. Perhaps somebody with better knowledge can tell you more.
  9. Tinners
    Tinners Member
    Seconded! I bought all my LEDs from t8ups and they are all spot on !
  10. audicruiser
    audicruiser Audi Heaven
    1,865
    Got mine from EBay, they've been fitted for 18 months with no problems. User Rhyso on here has the same ones too with no issues.
    Look at this on eBay:
    AUDI A3 A4 S3 Q7 TT NUMBER PLATE LED BULB white 239 C5W
    http://bit.ly/S8QQyu
  11. OVRA3
    1,079
    80
    Ive tried a few sets of LED bulbs and all of them have thrown up errors :-( cant find any that dont set off the canbus system :-(
    Thats why I thought maybe new units would sort the problem
  12. audicruiser
    1,865
    Well our cars are around the same age and have never had any errors with these...
  13. OVRA3
    1,079
    80
    Thats the annoying thing I know loads of forum memebers with no problems with the bulbs but I have tried so many times and just get a dash warning and they dont light up? Sensitive system maybe?????
  14. audicruiser
    1,865
    That happened when I fitted mine, just turn the bulb the other way in the holder.
  15. OVRA3
    1,079
    80
    Ok I'm going to order the ones you suggested and try again thanks mate
  16. Boon
    Boon Active Member
    441
    59
    I tried many different types in mine and none worked
    So I decided to wire a 5w bulb insde the boot to the connector on back of the handle/light unit and bought the cheap LED festoon bulbs (non canbus, no resistors etc) the standard bulb inside boot tricks​ the canbus into working and staying on
  17. OVRA3
    1,079
    80
    They work!!! Ok there is a knack to fitting these which I wasn't aware of so for those who are thinking of doing it this is how to do it.. Don't do it in daylight use a torch and do it at dusk.. Don't turn on the ignition don't even put the key in just turn the sidelights on so the number plates light up.. From here you can remove the holders and insert the led's, the LEDs move the connectors when you put them in so using a torch to see into the unit as you put them in wiggling the connectors till the light comes on..
    This is where I went wrong before I didn't realise that with the ignition off dis doesn't register an error when the light comes on and off so you can fiddle till you get the connection right without dis turning the lights off and registering and error It's fiddly but they do work eventually.. I also bought some new m3 10mm screws to replace the worn ones in the lens..
    Hope this helps someone..
  18. PixelVogue
    PixelVogue Member
    86
    they look really bright or is it just the picture?
  19. big harty
    big harty Member
    307
    15
    Don't do it there ****. Mine kept flickering and then error codes came up. Save your money matey
  20. PixelVogue
    PixelVogue Member
    86
    Cheers, went with t8ups instead
