Will these spec'd wheels fit my car?
Adam_A3_ Dec 6, 2013
  1. Adam_A3_
    Adam_A3_ Member
    226
    20
    Hi all
    Will a set of 19" rotars 9.0Jx19H ET33 fit my audi a3?
    I know 225/35/19 tyres are needed but i wanted to know if the wheels will fit.
  2. Eftwyrd
    Eftwyrd Member
    57
    14
    I'm going to say no.
    I run 19x8.5 et45 and have to run 215/35/19 and extra camber to avoid rubbing.
  3. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    574
    Unfortunately not.... Try and get them from an A4 if your going for 19" rotors...
  4. Adam_A3_
    Adam_A3_ Member
    226
    20
    Thanks.
    What ET should I be looking for and how wide? 8.5j?
  5. S3_Jacko
    1,734
    574
    The Rotors on the A4 are ET43 8.5"... If you run a 225/35 on them with a slight tyre stretch.. Remove a cpl of the rear wheel arch screws your car should be fine as long as its not mega low...
  6. Adam_A3_
    Adam_A3_ Member
    226
    20
    Cheers jacko. Appreciate it buddy.
    S3_Jacko likes this.
  7. manor13
    manor13 Active Member
    726
    110
    43
    will 18"x8" ET 45 fit on the a3 2.0 tfsi
  8. S3_Jacko
    1,734
    574
    yeah mate, that setup is pretty much want you want for the a3 looks wise... You'll gain about 15mm in wheel poke which is ideal considering a lot of guys use spacers to achieve that look
  9. manor13
    726
    110
    43
    :icon_thumright: bought a set of TD pro's then doubted myself lol
  10. Adam_A3_
    Adam_A3_ Member
    226
    20
    Just had a question on these wheel sizes.
    18" 7.5j et54. Do these have the right amount of poke on them or would i need to run spacers on my sportback?
  11. Adam_A3_
    Adam_A3_ Member
    226
    20
    Bump
  12. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    I'm in the process of getting a 9j at et45 up front on mine and its tight on the strut and does poke a couple of mm more then id like
